2.5 map?
Old Aug 19, 2011 | 11:31 PM
Dshif7411's Avatar
2.5 map?
so i am looking for a 2.5 bar map sensor for my 07 sc, i originally thought it was a 3 bar map but then i found out it didnt fit since it is for the lnf. is the 2.5 equivalent to the 3? and if so where can i get a 2.5.
thanks for ANY help or advice
Old Aug 19, 2011 | 11:51 PM
Omnigear's Avatar
por que?
Old Aug 19, 2011 | 11:55 PM
Sharkey's Avatar
iirc the stock tmap sensor (temp and manifold pressure sensor) is 2.5 bar. its the sensor on the top of the intake manifold. its not equivilent to a 3 bar, a 3 bar does -14.5psi to 29psi, 2.5 bar is -14.5 to 21.5psi.
Old Aug 20, 2011 | 12:00 AM
soundjunky's Avatar
you made me look this up - so part if from memory, and part is what I just found on the (mis)information highway...
Bar1 = vacuum only
Bar2 = reads pressure accurately up to 15psi
Bar3 = reads pressure accurately up to 29.4psi
Now the LNF map sensors are good to roughly 20psi ~ which I guess would coincide with your "bar2.5" comment...
The LNF Stage1 kit comes with replacement bar3 sensors for both the intake manifold as well as charge piping...
Does that help any?
Old Aug 20, 2011 | 11:23 AM
Pyros777's Avatar
Hes asking about the stock LSJ MAP. Its a "2.5" bar sensor, but is actually more like 2.78.
Anyway, its not the easiest sensor to find since most auto parts places have the wrong part number in their systems.
Thats why this thread exists:
https://www.cobaltss.net/forums/2-0l...number-211009/
Old Aug 20, 2011 | 01:34 PM
Dshif7411's Avatar
yeah it helps and is there a 3 bar map for the lsj? i have a bolt on zzp stage 3 kit and need one that can hold up bettter to the psi
Old Aug 20, 2011 | 01:48 PM
Pyros777's Avatar
The LNF GMS1 sensor is ~3.3 bar.
If you have HP Tuners you can apply the following change to make it work:
Originally Posted by Pyros777
If you want to run it in your car just change your Linear value to 329.43750, and your Offset to -6.35156.
Just to be sure you know though, your PCM can still only read up to 255kpa no matter what map sensor you use.
Old Aug 22, 2011 | 01:43 AM
Dshif7411's Avatar
Does anyone know where to get a 3 bar map for the lsj?
Old Aug 22, 2011 | 04:31 AM
insylem's Avatar
A few things
1: 2.5 bar = 36.2594344 pounds per square inch
2: 3 bar = 43.5113213 pounds per square inch
3: These are Absolute Readings.
4: Atmosphere Pressure - 14.7 pounds per square inch
5: 2.5 Bar = 21.5594344 pounds of boost
6: 3 Bar = 28.8113213 pounds of boost
So unless your planning boost levels above 21.5 psi then stick with the 2.5 Bar.
For some reason I must have done the math differently because my max boost (before header) was 17psi and somehow I calculated that I needed more then the 2.5 bar. Oh well.
Old Aug 22, 2011 | 04:42 AM
insylem's Avatar
Bar1 = vacuum only
Does that help any?
Ok this explains why I went with the 3bar instad of the 2.5
I'm pushing more then 15psi boost. (15.5 - 16, was 17 before my header install)
Aeroforce
Old Aug 22, 2011 | 09:05 AM
Pyros777's Avatar
3 Bar MAP Sensor 55206797 - Crate Engine Depot
Old Aug 22, 2011 | 10:21 AM
mrbelvedere's Avatar
were do you change that at in hpt
Old Aug 22, 2011 | 10:35 AM
Pyros777's Avatar
Engine Diag --> Airflow --> MAP Sensor
Old Aug 22, 2011 | 11:55 AM
is there any advantage to running a 3bar map
Old Aug 22, 2011 | 12:02 PM
Pyros777's Avatar
ONLY if you re-scale the rest of the tune to fake a 3 bar tune since the PCM can't actually read that high. To my knowledge nobody has done this yet. StreetDreamz said he did but thats about it.
Otherwise it is just a slightly lower resolution, yet very reasonably priced, replacement part.
Old Aug 24, 2011 | 11:14 AM
minizr1's Avatar
Will the 3bar physically fit onto the lsj intake manifold?
DarrenGC
Dec 24, 2021 01:55 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
