2.7 pulley
2.7 pulley
if you get a 2.7 pulley what other upgrades besides a belt would you need for the pulley to fit and work well? any pulley boys products or can you just throw the 2.7 pulley on and a belt and be done?
Nate
You need a hub, if you get a 2.7 pulley go with ante, hes awesome
Here is the list
Supercharger Pulley Hub (Stage 2 GM)
Supercharger Pulley 2.7 (Nates pulley, getthe 4 bolts to, use blue threadlock)
Bigger Injectors 60# Siemenz
Custom Tune (This is the biggest one!)
Belt Tentioner (R.A.W Sells one I think)
I suggest a intake and exhaust, whichever you prefer.
That should be it. Thats what you need to do it right.
Also the Stage 3 kit requires you to have the Stage 2 kit already installed. They do not sell just a Stage 3 kit, tis a upgrade kit from stage 2 to stage 3.
Here is the list
Here is the list
If you plan on going with a pulley system and you're currently stock I wouldn't suggest the GM style hub since it limits the size pulley you can run. If however you do want to use that style setup, I can make a GM style hub out of stainless steel which has a smaller diameter and will allow you to go down to 2.6 w/o snout machining.
Nate
Nate
