2.7 pulley
Old 02-18-2008, 09:55 PM
srcobaltss's Avatar
2.7 pulley
if you get a 2.7 pulley what other upgrades besides a belt would you need for the pulley to fit and work well? any pulley boys products or can you just throw the 2.7 pulley on and a belt and be done?
Old 02-18-2008, 10:01 PM
an0malous's Avatar
larger injectors and tuning obviously.
Old 02-18-2008, 10:03 PM
XM15's Avatar
I would get some cooling mods as well.
Old 02-18-2008, 10:04 PM
srcobaltss's Avatar
yeah i knew the tune and injectors. but no other pulleys need to be changed. just pop off the stock on and throw the 2.7 on, a belt, tune and injectors and its good to go?
J.CobaltLT's Avatar
even though im not a grease monkey...i think its pretty wise to get some good cooling mods with a pulley smaller than 2.8 IMO
Old 02-18-2008, 10:09 PM
red06s/c's Avatar
I think hes asking if you need a new hub.....and i THINK yes, you will need a new hub if you have the stock hub on.
srcobaltss's Avatar
well im getting stage III which comes with a dual pass. but i want a 2.7 pulley instead of the 76mm pulley.
Old 02-18-2008, 10:51 PM
BooSSted's Avatar
I think your going to need to machine the SC snout too. As far as I know, the BilletFlow pulley is the only one that fits over the stock snout.
Old 02-18-2008, 10:57 PM
an0malous's Avatar
nate makes a 2.7 for the S2 hub
Old 02-18-2008, 11:48 PM
nherbst454's Avatar
I actually offer a 2.7 for the GM stage 2 hub that fits with no snout machining. Also, if you go with my complete modular pulley system a 2.6 will fit without snout machining!
Nate
Old 02-18-2008, 11:53 PM
brownbandit9's Avatar
i think he may be asking if he needs a belt tensioner to go with the stage 2 belt or a larger idler pulley? if he isnt thats my question
Old 02-19-2008, 12:46 AM
Nyke's Avatar
You need a hub, if you get a 2.7 pulley go with ante, hes awesome
Here is the list
Supercharger Pulley Hub (Stage 2 GM)
Supercharger Pulley 2.7 (Nates pulley, getthe 4 bolts to, use blue threadlock)
Bigger Injectors 60# Siemenz
Custom Tune (This is the biggest one!)
Belt Tentioner (R.A.W Sells one I think)
I suggest a intake and exhaust, whichever you prefer.
That should be it. Thats what you need to do it right.
Also the Stage 3 kit requires you to have the Stage 2 kit already installed. They do not sell just a Stage 3 kit, tis a upgrade kit from stage 2 to stage 3.
Old 02-19-2008, 10:51 AM
Rent me! per hour
Area47's Avatar
the 2.6 barely clears.
the 2.7 clears just fine
you better pray a lot, or shift before 6700
Old 02-19-2008, 01:10 PM
srcobaltss's Avatar
yeah thats pretty much what im asking
Old 02-19-2008, 01:20 PM
UmeNNis's Avatar
lol... or pray for the money for a good tune.
Old 02-20-2008, 03:18 PM
srcobaltss's Avatar
why should i shift before 6700. if its tuned it should be fine.
Old 02-20-2008, 05:38 PM
nherbst454's Avatar
Here is the list
If you plan on going with a pulley system and you're currently stock I wouldn't suggest the GM style hub since it limits the size pulley you can run. If however you do want to use that style setup, I can make a GM style hub out of stainless steel which has a smaller diameter and will allow you to go down to 2.6 w/o snout machining.
Nate
Old 02-21-2008, 07:27 PM
what about for tensioning the belt..is stage 2 belt fine on 2.7 or does it need to be used with tensioner..thats what hes asking
Old 02-21-2008, 08:16 PM
nherbst454's Avatar
I believe most people running a 2.7 are either using an oversized or adjustable tensioner to limit the belt slip with that small of a pulley.
Nate
Old 02-21-2008, 08:21 PM
Sunburst_SS's Avatar
2.7 and stage 2 belt is fine.....ran it on my car for a while, never noticed any belt slip
Old 02-21-2008, 09:32 PM
XCRuna1201's Avatar
might need a pulley tensioner for that small...
Old 02-22-2008, 05:59 PM
srcobaltss's Avatar
what about 2.8 will that need anything special to work with my engine and pulley system. besides the obvious cooling and tuning
Old 02-22-2008, 06:01 PM
Rent me! per hour
Area47's Avatar
2.8, stage 2 belt. good to go.
with the 2.7 you can run without a bigger tensionor, but you risk glazing the belt in a matter of two months
Old 02-22-2008, 06:07 PM
srcobaltss's Avatar
i could use the 2.8 with stage II, full exhaust, intake and tune. and my engine will good
Old 02-22-2008, 06:24 PM
Rent me! per hour
Area47's Avatar
thats a loaded question.
Quick Reply: 2.7 pulley
