2.7 worth it?
Old Jan 27, 2009 | 04:35 PM
tdipowered's Avatar
2.7 worth it?
im getting the ott stage kit and meth...is it worth it to drop down to a 2.7? how much more hps would i be making? i want it to be moderately safe and i know its up to the t00n but i just want to make sure a 2.7 would be alright.
Old Jan 27, 2009 | 04:38 PM
1badBlueberrySC's Avatar
Get meth, and all other cooling mods... and yes the torque increase is worth it!
It wasn't as big a drop for me, comming from a 2.8 but from stock or 2.9 it's a HUGE difference and with you being generally close to Area47 you're golden for tuning!
Old Jan 27, 2009 | 04:44 PM
tdipowered's Avatar
cool yea next tuesday i am getting a 4 grand check so im gettin some goodies jbp header, cti downpipe, ott stage1, progressive meth kit, and the tb spacer (dont really want to put a hole in my intake) but yea i pm'ed area47 to see if he can help me out cuz ill be needing a tune for the meth and the 2.7 if i get it which from what you said looks very inviting..
Old Jan 27, 2009 | 04:45 PM
ShortStack's Avatar
You dont need the progressive meth kit... Actually, its better to get the standard.
Old Jan 27, 2009 | 04:46 PM
I myself as well as Area47 run the standard on/off type meth kit. Less to go wrong with them!
Old Jan 27, 2009 | 04:47 PM
ShortStack's Avatar
Yup..
with as much heat as the SC puts out.. its better to cool it as fast as you can...
Old Jan 27, 2009 | 04:50 PM
tdipowered's Avatar
is the only difference the little controller that makes it "progressive"?
Old Jan 27, 2009 | 04:51 PM
ShortStack's Avatar
Yes but that controller is like an extra 200 bucks.
Old Jan 27, 2009 | 04:52 PM
PhantomSS's Avatar
dont get the boost activated progressive kits... they do have issues. Maf based are much easier.
personally i didnt get more than 3 whp/tq from a 3.0 to a 2.8 due to the timing drop.
stock to 3.0 or 2.8 is a big jump though.
Old Jan 27, 2009 | 04:53 PM
Yes slowly increases the meth spray. Vs. just on and off.
I have 113* IAT2's after a 1-4 WOT pulls! with a 60/40 meth/water mix
Old Jan 27, 2009 | 04:59 PM
tdipowered's Avatar
ok so its better just to have it come on all at once then?
and wow thats really low! i am planning on doing the windsheild wiper fluid which is 70 water and 30 meth so i should be cool on the IAT2s...unless i can find some meth around here...
what PSI do yall have urs set to come on and what size nozzles?
PhantomSS's Avatar
one of the best mixes... 70/30 if your going hardcore.... i didnt want to risk more cuz im not ballsy like other old schoolers here
Old Jan 27, 2009 | 05:01 PM
tdipowered's Avatar
ok but is that 70 meth and 30 water?
Old Jan 27, 2009 | 05:02 PM
ShortStack's Avatar
Yes.
Old Jan 27, 2009 | 05:03 PM
ajjaro's Avatar
i was thinking 90/10, is that safe to run?
Old Jan 27, 2009 | 05:04 PM
ShortStack's Avatar
Its Safe... it would allow for more power through advancing but less cooling effect.
Old Jan 27, 2009 | 05:08 PM
tdipowered's Avatar
then what the hell is windsheild wiper fluid..thats what everyone told me to use....is it 30 meth and 70 water?
or
ajjaro's Avatar
30-40 meth and 60-70 water
Old Jan 27, 2009 | 05:09 PM
ShortStack's Avatar
Windshield wiper fluid is a mix of Meth and Water... i think its 70 water and 30 meth.. you MUST use the -20* stuff..
You buy a product called "heet" (black can) and you mix 2 of those in with a gallon of wiper fluid for iirc a 60meth 40water mix.
Old Jan 27, 2009 | 05:10 PM
tdipowered's Avatar
ok thats what i want then..i want to run safe and cool so thatll work for me thanks
Old Jan 27, 2009 | 05:12 PM
You have to figure what you are using it for. I am using it for the little added octane but because with a 2.7 ring on their your gonna be getting really HOT!
90/10 is okay but I would only do that for track days or something like that... not for everyday driving!
Troof! I use -20* washer fluid and HEET mixtures (YELLOW bottles).
1 bottle of heet per gallon of -20* washer fluid makes in a roundabout way a 60/40 mix
Last edited by 1badBlueberrySC; Jan 27, 2009 at 05:12 PM. Reason: Automerged Doublepost
ShortStack's Avatar
Sorry i knew the mixtures were a bit off.. i could have swore it was the black can though... lol..
Old Jan 27, 2009 | 05:13 PM
ajjaro's Avatar
well i was gonna add another cooling mod, something to do with a reservoir, its being explained to me on the "gotta beat that hemi thread" and i will have a dual pass h/e for added cooling on top of the other mods
Nope the yellow bottle is 100% methanol
ShortStack's Avatar
Yea i had the cooling thing as well.. i could seriously touch my intake manifold.
