2.79 pulley?
Old Jan 3, 2008 | 10:56 PM
blown07's Avatar
2.79 pulley?
will i have to buy a new tensioner if i allready have stage 2 , to install the cobalt addiction 2.79 pulley
Old Jan 3, 2008 | 10:58 PM
G85 SS's Avatar
I don't think so, but don't take my word on it. I have the 2.9 and didn't have to buy a tensioner.
Old Jan 3, 2008 | 11:01 PM
Bika's Avatar
Fail Less.
you dont need it. unless you go to a 2.6 you wont need it.
Old Jan 3, 2008 | 11:03 PM
blown07's Avatar
is this to much boost , do i need another method of cooling?
Old Jan 3, 2008 | 11:23 PM
momo_avatar300's Avatar
you should be seeing about 18psi, and i would at least get a CAI. i am installing my stage 2 and ca 2.79 pulley tommarrow, but i am more worried about going lean or over working the injectors.
Old Jan 3, 2008 | 11:59 PM
Bika's Avatar
Fail Less.
and the OP should be as well. 2.9" is the lowest you can safely go on a stage 2 tune and injectors with no other mods (exhaust, meth, tuning, etc)
and an aftermarket intake will do nothing to cool your IAT. our cars come stock with a CAI. all you will accomplish with an aftermarket one is slightly more airflow and a louder whine from the s/c.
Blown07: you dont need more cooling mods to run that pulley, but they will help.
Old Jan 4, 2008 | 05:37 PM
well i have exhaust and a CAI and i should have my stage 2 and 2.8 back for the dealership in about an hour ( i hope )... so ill let you guys know what happens. Ive seen alot of guys running taht setup so i think ill be ok. If not then its under warrenty. ill put my meth back on if i need to.
Old Jan 4, 2008 | 05:47 PM
CobaltSS 16's Avatar
The lowest I would go is 2.9 on a GM stage 2 tune. Below that, the injectors get a little crazy past 6k rpm. I would at least get tuned if your putting that pulley on there.
Old Jan 4, 2008 | 05:54 PM
i saw a guy on here with stage 2, 2.8 and a 50 shot of nitrous...and he is still on a stage 2 tune. but like i said ill let yall know when i get my car back....GM takes ******* forever to do simple tasks.
Old Jan 4, 2008 | 06:08 PM
blown07's Avatar
where is the best place to get the 2.9 to fit my hub, and i do plan on getting the header and cat back
Old Jan 4, 2008 | 07:54 PM
i just got my car back and it is badass. i just beat my friends STI from a dig!! only by a car length tho. i love seeing 18psi from the 2.79!!
Old Jan 4, 2008 | 08:03 PM
burntorange's Avatar
I have the 2.79 with just the stage 2 tune, full bolt ons and spraying the 125cc of meth, untuned and love it...but am going to be getting tuned soon. and get the other cooling mods.
oh, and no you do not need a tensioner. Just the stage 2 belt.
Last edited by burntorange; Jan 4, 2008 at 08:03 PM. Reason: Automerged Doublepost
Old Jan 4, 2008 | 08:15 PM
i have meth but no controller...you think if i spray from a push button it will still give me power
Old Jan 4, 2008 | 08:32 PM
.......well.......don't really know on that one.... my car had to learn the alky....it like had a fit when it started spraying....it was popping and shaking and going nuts....then it smoothed out.
Old Jan 4, 2008 | 08:47 PM
Bika's Avatar
Fail Less.
you should get a tune for running meth, but dont run a water/meth tune without spraying it. the car acted like it was "running rich" when you sprayed it, hence why a good meth tune will add a lil more timing and lean out the commanded afr.
activating the kit with a push button will technically work, but only if you can manage to activate/deactivate it at the correct time. much much easier/safer to get it on a boost activated switch, if not a progressive maf controlled switch.
Area47 can provide more details on w/i
Old Jan 4, 2008 | 09:02 PM
yeah, I am getting tuned soon....that will be pretty sweet!!!
Old Jan 4, 2008 | 09:18 PM
im probaby just gonna sell my kit cause im lazy and dont feel like bothering with it.
Old Jan 5, 2008 | 05:25 PM
Bika's Avatar
Fail Less.
blown07 - the best pullies for hte stage 2 hub are made by Nate. nherbst454 is his name on here. smoothflowpulleys on ebay
Old Jan 6, 2008 | 03:37 AM
ssaddiction's Avatar
go with a pulley from nate there the best light and great looking i got a 2.9 on and i love it...and a CAI will not change IAT's but itll give a little more umph and makes the supercharger whine to the moon
Old Jan 6, 2008 | 03:45 AM
Super_SS's Avatar
u really dont need it,but i recommend it..i changed mine since my stock tensinor got loose for some reason,plus with the zzp tensinor u can adjust it buy pulley size...
Old Jan 6, 2008 | 03:50 AM
kwest's Avatar
ok guys im unfamilair with meth kits..how exactly do they work and what exactly do they do?
Old Jan 6, 2008 | 04:15 AM
Super_SS's Avatar
they help with the cooling process
Old Jan 6, 2008 | 10:30 AM
blown07's Avatar
thanks for all the help guys
Old Jan 6, 2008 | 11:21 AM
efrommel's Avatar
Man I buy the 2.8 pulley from zzp performance and when i installed my belt slip and broke one of the lines. And now i need the adjustable tensioner from zzp performance and another 70 bucks belt...
I recommend the tensioner.
And my question is how much boost is the 2.8 pulley???
Old Jan 7, 2008 | 02:38 PM
kwest's Avatar
ok guys i need some help also. I got my 2.85in pulley today from Nate and i went to install it. I used anamoulus' method with the crow bar which works perfectly but the blue bolts from my stage 2 are waaay to over tightened.so i tried to position the crow bar to stop the pulley from slipping so i can unbolt the blue bolts and the ratchet slipped and the pulley didnt move and i pretty much stripped one of the blue bolts. what do i do now??
