2.79 pulley?
Old Jan 7, 2008 | 03:47 PM
Bika's Avatar
Fail Less.
gotta take the blower off and drill out the stripped bolt. find yourself a bench vice and a good drill cuz you're gonna have fun.
the 2.8" pulley will usually give 17 - 17.5 psi.
Old Jan 7, 2008 | 03:49 PM
M-Dub's Avatar
No you do not need the adjustable tensioner... if I remember right the tensioner is good to a 2.7(ish) don't quote me on that but a 2.80 is fine!
Old Jan 7, 2008 | 03:56 PM
Edubs's Avatar
I'm on about 10K w/ my 2.79" & Stg 2 belt. No issues here...
Old Jan 7, 2008 | 04:08 PM
invisible's Avatar
I have a 2.8 pulley, you dont have to have the tensioner but if you dont have it, you wont be seeing 18 lbs of boost though, only about 15-16.
haha i had to do the same, just make sure you get a good sharp bit and take ur time and its pretty easy, you can go get another bolt from your auto store but i dont remember what size it was.
Old Jan 7, 2008 | 04:09 PM
TxLonghorn#1's Avatar
I may have missed this, but where can I get a 2.79 pulley??
Old Jan 7, 2008 | 04:17 PM
invisible's Avatar
i got mine from cobalt-addiction.com, but i think you can get them from zzperformance.com, and nate
Old Jan 7, 2008 | 04:18 PM
Area47's Avatar
Rent me! per hour
boost levels are dependant on your altitude, and your exhaust.
Old Jan 16, 2008 | 06:18 PM
switching to a 2.7, I think I might get the pulley tensioner for a peace of mind kind of thing....
Old Jan 16, 2008 | 11:11 PM
kwest's Avatar
ok guys i got a polished 2.85in from nate (great by the way) and i tried installing it. well the stage 2 bolts are waaaaay over tightened to get loose. i was told that if you put a torch on it and heat it up that the lock tight the dealer uses comes loose and you can easily get them off. well i had a propane torch and pretty much caught the bolt on fire for atleast 2 minutes and it still didnt come off!!!! and i actually wound up stripping one of the bolts. so what you guys think? unbolt the whole blower and drill them out?? (dont really wanna do this!!!)
Old Jan 17, 2008 | 08:47 AM
Edubs's Avatar
If you really stripped one of the bolts, that's your only option right now anyways. It's really not bad at all to take the blower off. Takes 10 minutes with basic tools...
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
