2.8 or 2.9?
Old Nov 5, 2010 | 10:28 PM
CanadianCobalt's Avatar
2.8 or 2.9?
I've searched, and havn't really found a straight answer. Getting a ZZP Stage 3.
Currently my car is completely stock, and I would be getting the S3 HE. I want to get a dual pass by spring time (FWIW, it's getting cold here. Winter tires have already been on for a bit ).
Anyways, is a 2.8 that big over a 2.9? Reliability?
Gas mileage on the highway? (I do a lot of highway)
Thanks.
Joel
Old Nov 5, 2010 | 10:37 PM
Reaper06's Avatar
gas mpg prob will improve either or, realy it comes down to do you wan 42lb injectors or 60's. For the 2.9 maxes out 42's for most tunes and the 60's you can run with either pulley sizes. Just need to think how far your going to pulley down in the future but generaly speak the 2.8 and 2.9 are rather close to maken same power, more or less all about the tune, and other mods you have. Any smaller of pulley then you will need more than justa h/e and endplate for heat become a issue, but the smaller pulleys will net you more trq. I say do a 2.9 setup and get you a header/dp combo, decent exhaust and intake and learn to drive it to its full potential. Nuthn like seeing 400hp car at track still running high 12's and low 13's.
Old Nov 5, 2010 | 10:57 PM
ULWizSS's Avatar
Have the parts in my sig and am adding a 2.8 tomorrow instead of the 2.9. Will let you know how it feels.
Old Nov 6, 2010 | 01:05 AM
Bluelightning's Avatar
Got Bewst?
Doesn't the stage 3 come with 60lb injectors? Get the 2.8 without a doubt. It's very safe and perfect for bolt ons
Old Nov 6, 2010 | 01:45 PM
insylem's Avatar
Thanks.
Joel
Go for the middle
I have a ZZP 2.85" Pulley
Old Nov 6, 2010 | 02:49 PM
ULWizSS's Avatar
If this is directed at me then maybe the GM3 is a little misleading. Its currently just the GM3 Tune with 42's in there and a 2.9. My injectors are good enough to run the tune apparently since my injectors are barely reaching its max during 1-4 WOT pulls.
So i just ordered the 60s and will now officially be considered a true GM3. 2.8 and S3 zzp HE is sitting in my car just waiting to be installed. Will most likely have the pulley and injectors installed at the dealership since it only cost me $35 last time to change out the pulley.
Will keep you posted when i run it next Sun hoping i get anything under 13.617
Old Nov 6, 2010 | 02:52 PM
blk06cbltss's Avatar
get the 2.7 =D
Old Nov 6, 2010 | 04:35 PM
Got Bewst?
No it was directed at the OP. Hes getting a ZZP stage 3. Definatly let me know you're times next Sunday
Old Nov 6, 2010 | 07:25 PM
Reaper06's Avatar
diff in 2.8 n 2.9 is 5hp tops! It's the tune. Doubt you'll feel a diff it that slight of a change. And to be true gm3 I would think you would need the gm3 pcm with its features not a zzp or others.
Old Nov 6, 2010 | 10:35 PM
Well I picked it up today
I opted for the 2.8 over the 2.9, thanks for the input. Glad to hear its safe. Go big or go home I guess (Nobody tell me to get a turbo kit, not going THAT big .)
What octane are you guys running with it? It says they reccomend 93. I run 91 (Premium here). It won't knock will it?
Next up is the Intake .
Joel
Old Nov 7, 2010 | 12:49 AM
Got Bewst?
Joel
No it won't knock. I run 91 being in Canada as well.
Old Nov 7, 2010 | 12:51 AM
Glowbalt's Avatar
ya me too 91 is premo here
Supercharged06SS
Oct 5, 2015 09:13 PM
SlowSaturn
Sep 28, 2015 11:03 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
Silverbullet333
Sep 22, 2015 10:55 AM
medic710
Sep 6, 2015 08:53 PM
