2.8 and 60lb problems after install
Old Aug 22, 2008 | 10:59 AM
Darkmanx's Avatar
Originally Posted by Z06vettespd
I'm going to get a tune today cause my buddy is bringing his tuner over and i looked on the hp tuners website and they'll have the dl i need for the injectors. Thanks guys for all your help.
Make sure it is a base tune for 60lb injectors and not a actual tune , because if you upload someone else tune you can mess your car up faster than the 60lbs would.
Old Aug 22, 2008 | 11:01 AM
Z06vettespd's Avatar
True, so basically i need to do the basic tune for my setup and build from there?
Old Aug 22, 2008 | 11:03 AM
zay52790's Avatar
talk to 06blackg85ss, i got a base tune for a 2.8 and 60's from him.
Darkmanx's Avatar
True, so basically i need to do the basic tune for what i have and build from there?
yes they have base tunes , that are made to get you from point a to b. less timing and a little rich and then you have to fix them , but it will be safer than what your doing now.
Old Aug 22, 2008 | 11:15 AM
BeermanSSSC's Avatar
there is a injector spreadsheet that you can download off the hptuners forum. It has the conversions on it, all you do is put in your flow ratings and it gives you your #'s
Old Aug 22, 2008 | 01:36 PM
LopsidedJester's Avatar
60 lb tune thread This thread may help your friend out with the 60 lbers, it shows how to tune the flow rates without maxxing the table and gives the correct offsets for the injectors. Just helps all around if you're new at it.
Old Aug 22, 2008 | 01:43 PM
Awesome! Thank you.
Old Aug 23, 2008 | 07:10 PM
I looked on the HP tuners website and they only have tunes for 2.6inch pulley and 60lbs none for 2.8 and 60lbs. I loaded the one from the website and there's a huge diffenence in performance, but i would like to have a tune from a 2.8 ad 60lbs to be safe. If anyone knows where to get one let me know. Thanx
Old Aug 23, 2008 | 07:16 PM
95cam86roc's Avatar
Well right now that tune for the 2.6 and 60s is by far safer than you running a 2.8 and 60s..... Any reason why you didnt locate a tuner before you decided it was a good idea to install your parts? Honestly i'd return it back to stock until you find someone to tune it. Just my two cents
Old Aug 23, 2008 | 07:20 PM
I'm pretty new and ignorant when it comes to this stuff and i was told to go with the 60's over the 45's for more performance, but i didn't know how it would effect the car. My buddy knows what he's doing so tomorow he's going to take a look at it. Wouldn't the 2.6 tune be worse for the car because it would be telling the injectors to send more fuel?
Old Aug 23, 2008 | 07:23 PM
  #36
BlueSS-supercharged's Avatar
just dont get on your car. right now your running a too rich so dont get on it al all.
Old Aug 23, 2008 | 07:27 PM
  #37
95cam86roc's Avatar
I was just wondering, i wasnt trying to be a dick. We all have to start somewhere to learn from. I think you just got a lil excited about moding the car n jumped the gun since you didn't know what all was completely involved in moding it for the 2.8 and 60s.
Old Aug 23, 2008 | 07:42 PM
  #38
LOL I know your not being a dick. My buddy tells me the same thing about me getting all excited and putting all this stuff on my car without knowing whats up. I'm sending out a couple of emails to see if some people can get me a tune for it, but we'll see.
Old Aug 23, 2008 | 10:02 PM
  #39
theneelster's Avatar
Last night i installed my 2.8inch pulley, 60lb injectors and smaller belt. My problem is that its running on the stock tune. At about 4-5000 rpm the car boggs like its getting too much fuel to the combustian chamber. What i'm thinking the problem is is that on the stock tune the computer was giving the stock injectors tons of fuel and now that the 60lbs are on and the flow rate on them is much higher, it's drowning my engine with too much gas. Tune?? My buddy has an HP tuner but we have no clue how to use it. If anyone could help that would be awesome. thanx
Download a canned tune from the hp tuners site until you learn. There should be a ton on there for the cobalt or even redline.
Originally Posted by ShortStack
And thats exactly wahts happening... your going to really hurt something... i would take off the 60s and go back to stock untill you learn how to tune, and you just cant do that over night..
You might be able to have someone send you a tuner file for the 60s, and you can use hp tuners to hook it up to the car... And honestly if you dont know what any of those numbers mean when you try to use hp tuners, dont try to tune your car cause you could end up hurting something even more...
If you dont get those 60s out soon your going to need a new engine.
Running rich? Doubt it.
Last edited by theneelster; Aug 23, 2008 at 10:03 PM. Reason: Automerged Doublepost
Old Aug 23, 2008 | 10:15 PM
  #40
ShortStack's Avatar
Hmm... you think so? What if he floored it a good couple times thinkin that it was just goin to ride out...
I dont think it would be helpful.. no?
  #41
eurochevy's Avatar
ok well i'll be a dick and say ur an idiot for thinking that the stock shitty tune could handle 60's and a 2.8 ...but thats just my opinion
Old Aug 24, 2008 | 04:38 PM
  #42
did you get this worked out yet man?
Old Aug 24, 2008 | 05:45 PM
  #43
Josh@ottp's Avatar
Why didn't you get our tune when you ordered the pulley and injectors? We can email it to you. PM me for info and pricing.
Old Aug 24, 2008 | 10:18 PM
  #44
I loaded up a tune from hp tuners for a 2.6inch and 60's, the car was running really rich so i fallowed the 60lb thread insturctions and that tune is more modest on power and idles better, but i'm still running too rich so i think i'm going to just buy a tune for my setup.
Old Aug 24, 2008 | 10:42 PM
  #45
Zach06CobaltSC's Avatar
that would be the best plan. Unless you want to drive to ohio like i am to get a really great tune from tom.
justinchinn
Oct 2, 2015 12:18 PM
SlowSaturn
Sep 28, 2015 11:03 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
