2.8 only pushing 14-15 psi
Old Jul 1, 2010 | 02:06 PM
scotch89's Avatar
so i have a stage 3. 2.8 pulley, 42 injectors, duall pass endplate, S3 HE. when i first got my stage 2 on i was hitting 16psi. now latley im hitting 14-15. anyone now y? also for all the 42lb 2.8 haters, the injectors are at 88% IDC. so i now its not them. vac leak?
Old Jul 1, 2010 | 02:07 PM
05Slowline's Avatar
no way your inj are only 88% IDC it's not possible. unless you're only reving to 5.5-6k
Old Jul 1, 2010 | 02:14 PM
06cobalt racer's Avatar
i only hit 15 with mine but it is because i have exhaust so there is less resistance.
do u feel a loss of power? boost is a measurment of restriction. so higher boost dosnt always mean more power.
Old Jul 1, 2010 | 02:15 PM
scotch89's Avatar
about 6.5
Old Jul 1, 2010 | 02:16 PM
05Slowline's Avatar
lawl your idc's are def over 100% and you lost a psi of boost woo hoo pressure changes from day to day weather changes conditions change etc etc etc.
scotch89's Avatar
it feels the same i guess.....idk i just like seeing that little needle shoot up lol
Old Jul 1, 2010 | 02:21 PM
RoadconeTuning's Avatar
sounds like youre blower is starting to wear and clearances are starting to get a bit loose and since it doesnt seal as well its not able to hold as much boost.
pretty sure he could have the fuel pressure turned up which effectively lowers duty cycle and generally makes the pattern better.
Old Jul 1, 2010 | 02:23 PM
SS4ME's Avatar
You live in Wyoming where it is at least a mile high in most places. You say you boosted 16 psi on the stage 2 kit but only 15 on stage 3 with a 2.8. Was it really hot when you noticed the change?
Old Jul 1, 2010 | 02:26 PM
scotch89's Avatar
well the temps were around 50-65*f so i guess that could of made it change like that. i've always had a 2.8. stage 2 is injectors and pulley, stage 3 is with a HE
Old Jul 1, 2010 | 02:27 PM
revolution607@yahoo.'s Avatar
i only hit 15psi on my 2.8...
scotch89's Avatar
elavation here is 6800
Old Jul 1, 2010 | 02:28 PM
rnjmur's Avatar
1. Wyoming is 4000ft+ above sea level. A 2.8" pulley would very likely be at lower IDC at those altitudes, especially if running a leaner tune than GM stage 2.
2. How long have you had stage 2? Have you had it during hot weather yet? The hot air is much less dense and you can see much lower boost levels.
Old Jul 1, 2010 | 02:29 PM
scotch89's Avatar
hummm, wel maybe i was wrong lol. thanks for the replys
sundevil07's Avatar
50-65 degrees? Jesus it doesn't get below 90 here ANY time right now
Old Jul 1, 2010 | 02:32 PM
scotch89's Avatar
1. ya this is why i always get into an argument over my IDC.
2. not yet, its been around 80*F so far, but i just got my new clutch so i cant really see what she will do now.......200 more miles,actually does anyone now how long it takes to break in the gm staged clutch? when i first started to drive it, it sucked. now it feels freaking awsome, so im wondering if its all ready broken in. i was going to baby it untill i hit about 500
Old Jul 1, 2010 | 02:34 PM
im also 4000 ft above sea level so im pretty sure youre ok.
lol i also have the same clutch and i waited 500 miles to go anywhere above 3.5k rpms.
you should be good after 500 miles
Last edited by revolution607@yahoo.; Jul 1, 2010 at 02:34 PM. Reason: Automerged Doublepost
07SuperchargedSS's Avatar
haha **** that!!! Thats too hot
Old Jul 1, 2010 | 02:35 PM
scotch89's Avatar
lol do u also have the S3 HE? cool how do you like yours?
Old Jul 1, 2010 | 02:38 PM
lol i dont have a S3 HE but i do have a second HE.
and i love the clutch holds so much better than stock.
I never noticed this until i drove my friends stock ss/sc but its considerably harder than a stock clutch.
Old Jul 1, 2010 | 02:45 PM
scotch89's Avatar
sweet, ya i cant wait to see what it really feels like at WOT. i ended up cracking my tranny case, so the dealership ended up putting a new tranny with LSD since i already had that. then GM wheel hop kit, and then my clutch i only had to pay for the clutch and parts and 1 hour of labor. it was like 504.00, i really cant belive they did that for me ..........dam wheel hop lol
Old Jul 1, 2010 | 04:32 PM
rnjmur's Avatar
You should usually break in a clutch about 500 miles.
Old Jul 2, 2010 | 12:12 PM
InfraRedline's Avatar
I only hit 15.5 psi on a 2.7 with full exhaust, and my elevation is about 1600ft. Its been 95+ degrees the last week and hasnt gotten under 85 at night so i have been easy on it lately lol
Old Jul 2, 2010 | 12:15 PM
Supercharged06's Avatar
im at sea level and according to my interceptor i only get 15.3 psi at 7k rpms on my 2.8
vibrant header/dp and hahn 3in catback
Old Jul 2, 2010 | 12:32 PM
Thats my exhaust setup Im catless though
Old Jul 5, 2010 | 05:47 PM
Coby06's Avatar
bump up your injectors to 60# you'll notice higher psi.
