2.8" pulley???
Wow, I have the stage two pulley and I see intake temps around 155 just cruiseing around town. If I beat on the car a little it ranges from 160-170, and I know the car is pulling timeing. My next mod is going to be the CA heat exchanger and Dual Pass plate, but if the water injection is helping you that much I may consider that one next. You also have to keep in mind I live in Las Vegas where the temps are at 120 during the day and rarely drop below 100 at night this time of year. What do you think I should get next considering the enviroment I am in?
every little bit helps.
it is just as hot here as it is there, so i know how you feel in the summer time
ok all this IAT temps and everything about running a 2.8 pulley, cant this be fixed? if you run a cobra or C/A front mount heat exchanger with a dual pass kit, would it make the 2.8 safe to run with the stage 2???
patooyee
Oct 1, 2015 01:07 PM
