2.8 pulley
Old Nov 5, 2007 | 04:38 PM
SSalexSS's Avatar
2.8 pulley
i jsut put a 2.8 pulley on my stage 2 tune there thigns where ppl say its not good n others say its fine... but i also have a cobra HE which i bought from some member here.
jsut to make sure it goes
Cobra-pump
cobra-stock(hose wise)
shoudl i b safe?
Old Nov 5, 2007 | 04:40 PM
KillerBee's Avatar
No cause its gunna lean you out asuming since you have stage 2 tune you have 42.5 lb injectors and a 2.8 is way to small to much air not enough fuel
Coblt ss super's Avatar
i think it goes,
pump to intake mani
intake mani to stock h/e
stock to cobra
cobra to pump
and its not cooling that people are talking about its your injectors overdoing themselves to keep the car not run lean i think it is
Old Nov 5, 2007 | 04:44 PM
Avrj123's Avatar
I've been running it that way for a while, but i had someone with HP Tuners to adjust the stage 2 tune before that it was running rough.
Old Nov 5, 2007 | 04:59 PM
ggarcia86's Avatar
i've ran the set up for a while, and recently my car starts breaking up at high rpms. i am staying out of the 6krpm and up zone untill i can get my 60#injectors and tune from new era performance
i dont think the problem is running lean, i think its that the injectors go static and get stuck in the open or closed postion and will cause a misfire. but thats my opinion
Old Nov 5, 2007 | 05:22 PM
Area47's Avatar
Rent me! per hour
i have a log of a straight stage 2, 2.8. intake.
i can show you where it is knocking, and what happens up top with it. the only way you can save it from being angry is water injection. or bigger injectors. it will live if tuned right. if not, you may or may not run into issues.
Old Nov 5, 2007 | 05:40 PM
SSalexSS's Avatar
Originally Posted by Coblt ss super
i think it goes,
pump to intake mani
stock to cobra
cobra to pump
the way i have it is i have all the stock hoses from the reguarl H/E the same execpt i took the pump one out and replace that one with the cobra so its goes cobra to pump now then then i connect the other side of cobra to the stock H/E
Old Nov 5, 2007 | 05:45 PM
an0malous's Avatar
you guys make it to complex.
Run a new hose from the OUT side of your stock H/E, to the IN side of your cobra, then from the OUT side of your cobra, goes back to the pump
your just adding another rad in series.
Old Nov 5, 2007 | 05:47 PM
SSdan's Avatar
By far the simpliest post EVER concerning a second H/E
Old Nov 5, 2007 | 05:56 PM
TurboTommy's Avatar
I think its safe to say most wont go lower than 2.9 on a stock stage II tune without w/i
Old Nov 5, 2007 | 06:06 PM
SSalexSS's Avatar
okay that what i did i was just making sure.. i just took off the 2.8 and put the s2 pulley on
does any one have 60ib injectors for sale?
Old Nov 5, 2007 | 06:13 PM
Area47's Avatar
Rent me! per hour
better question. do you know anyone with hp tuners, or can you tune a car?
Old Nov 5, 2007 | 06:15 PM
anthonyS88's Avatar
hey ssalexss where in fla r u at?
Old Nov 5, 2007 | 06:17 PM
M-Dub's Avatar
I wish I knew someone that did!
Old Nov 5, 2007 | 06:19 PM
Area47's Avatar
Rent me! per hour
me too
Old Nov 5, 2007 | 06:20 PM
anthonyS88's Avatar
thats what i was going to ask him lol
Old Nov 5, 2007 | 10:25 PM
SSalexSS's Avatar
i heard of revextreme in tampa they have hp tuners
also i am locating near sarasota
Old Nov 6, 2007 | 12:37 AM
Avrj123's Avatar
Try this post, he was selling flow matched injectors with the harness for $200 I think.
https://www.cobaltss.net/forums/parts-66/fs-60s-w-harness-intense-2-6-ngk-wideband-header-downpipe-cobra-h-e-etc-83495/
Old Nov 6, 2007 | 08:36 AM
QuikSilverSS's Avatar
re
I have been running my 2.8" pulley for over a year and when I dyno'd my car the a/f was great, wasn't running lean at all, i have had absoluatly 0 issues with my setup...but if I were to do it again I would just stick with the 2.9" pulley, less heat, better IDC's, probably more reliable...I also dont run my car wide open for long periods of time either...run it through the gears and then let it cool down for several minutes before doing it again, plus I live in Canada and the temps are lower than some of the members in the southern states, I am definatly going heat exchanger and dual pass in the spring. I would like to see the logs that Area47 has when he had the same setup, can you post them please?
Old Nov 6, 2007 | 11:00 AM
Area47's Avatar
Rent me! per hour
i will when i get a chance too
Old Nov 6, 2007 | 01:04 PM
Deathscythe's Avatar
I know this may sound silly, but is there anyway to have your car tuned w/o the extra gear? ( gauges, wideband).
Old Nov 6, 2007 | 02:24 PM
Avrj123's Avatar
It can be tuned with hp tunersfairly accuratebut for fine tuning dyno and wideband help. As for temps h/e exchanger helps, i have a cobra and cooled down a bit, wiing to see when italian joewill have more dual pass plates
Old Nov 6, 2007 | 02:28 PM
Area47's Avatar
Rent me! per hour
afr's differ from dyno to the street.
Old Nov 6, 2007 | 02:38 PM
Avrj123's Avatar
I agree butif your not running it hard all the time,you can get a pretty good tune off a dyno. A friend just blew his gsr integra that way, tuned on dyno, and fried a piston on a quarter mile for being to lean.
Old Nov 6, 2007 | 03:29 PM
SSalexSS's Avatar
hmm if u get a tune with a 2.8 would u have to retune if u go 2.7?
