2.8 Pulley with Gm kit
Old May 6, 2006 | 01:29 AM
  #126
Asphalt Assault's Avatar
Originally Posted by Floridas Finest SS
So how is it that a stage 1 with a 2.8" pulley is equivalent to a stage 2 with the 3" pulley? since basically they are the same thing just one is a smaller pullley shouldn't the stage 1 be greater since its the same kit? and will someone please give me a straight answer is it because of the reflash because i was possibly misinformed when i read the reflashes for both stages were the same?
Same part or reference # for GM technician. then GM asks do you need stage 1 or 2 reflash?
the plan is to get stage 1, ask for stage 2 reflash, then put on the 2.8 or 2.7 pulley and belt. You need to be in tight with the dealer who is willing to ask for stage 2 reflash when you have bought the stage 1 kit. but they shouldnt care to much.
Old May 6, 2006 | 07:46 PM
  #127
PauL500x's Avatar
So how exactly is a non-slip pulley different from a regular one. I know it doesn't slip but how does it work? I won't need a tensioner with that right? What about a larger idler pulley...how does that work?
Old May 7, 2006 | 08:34 PM
  #128
Pully Police's Avatar
Are you sure????????????????? I believe that the instructions for the stage 1->2 kit were posted and they indicated that no further reflashes are needed.
Old May 7, 2006 | 09:52 PM
  #129
PauL500x's Avatar
Originally Posted by maxpit
I have stage 1, the stage 2 belt, a 2.8 pulley,and an intake. 18.4PSI at 6800 rpm's. Still runs rich like 10.6.
I want to put the 2.7 Billetflow. Will I still run a little rich and what is the ratio is the perfect a/f ratio(10:1?)? Will other mods like intake and exhaust effect this?
Old May 7, 2006 | 10:04 PM
  #130
2K5SS/SC?'s Avatar
10:1 is crazy rich. That's what our cars run stock for the most part. 12.5:1 would be beautiful. I've been wondering the same with the 2.7" pulley though.
Old May 8, 2006 | 04:53 PM
  #131
cds00bsmg's Avatar
1.) Are there any of you that have the GM stage II package and a 2.8" pulley? (SEE MY P.S.)
2.) If you answered YES to question 1, do you have any time slips, video, or any numbers of what the car is putting down?
3.) Also, I know that some have been asking if I believe the SFPH pulley will work with the GM setup, of if there is a pulley that will?
I ask all of this because I think Im going to use my discount to get the stage II package, and then slap a 2.8" pulley on it from SFPH and wondered what kind of numbers and times the thing should run. I want to get the stage II kit so I can put the GM 3. whatever" back on there for warranty work.
P.S. I read that someone here earlier purchased a stage I kit, and also somehow got a stage II belt. Is there a part number for the belt, or how was the stage II belt acquired?
Chris~
Old May 21, 2006 | 06:44 AM
  #132
CobaltSSilver's Avatar
Chris~
Earlier in this thread it was posted that the hub that comes with the stage 2 does not work with the SFPH, you will need to pull it and go with the whole set from SFPQ. It's something I am thinking about. I just got my stage 2 put on today. Loving it but wanting more of course. For now I am going to add GMPP Header, either magnaflow or corsa *whichever is easier on the ears for cruising* and the K&N filter swap because I don't want to deal with the CEL from all the other CAI. NGK iridium plugs are on the list as well. What gap is working best out ther for folks?
Hopefully doing all that fist will wet my whistle for power. If that is still not enough then I will go with the 2.8" SFPH. The injectors from Stage 1, belt from stage 2 will all be fine to run the 2.8" non-slip. Just need to get the SFPH hub and puller tool from what I understand. That is probably the best set-up as a daily driver and that is my goal, very reliable, but enough tractable street power.
With the Stage 1 with 2.8" pulley how long do you all think the clutch will hold up? Is that the only weakspot if I keep the Wheel HP under say 285-300?
Also for the whole belt part add-on there may be a way to order a 'stage 2 replacement belt' I mean they gotta have a way to replace the belt if it cracks, shreds or is faulty ya know.
Old May 21, 2006 | 09:14 AM
  #133
SS_SC_Cobalt's Avatar
Currently I am working with a pulley vendor to get a 2.8" ring for the gm hub, my ported and polished s/c is on the way there for measurements with the gm hub...STAY TUNED!
Old May 21, 2006 | 09:18 AM
  #134
FAST06SS's Avatar
My big question is this,
WHY did you waste your money on the GM stage2 kit only to void your warranty to go to a 2.8 pulley??????????????????????
They have tamper proof bolts on the pulley w/paint to prevent exactly this from happening.
Old May 21, 2006 | 09:20 AM
  #135
you have got to be kidding, replacing the bolts before using them is a small price to pay...this way I keep the stock look and go smaller but if something happens I can still put the 3" pulley on and take it in.
Old May 21, 2006 | 09:34 AM
  #136
FAST06SS's Avatar
1 time use?? Makes sense to me
To quote the guy who just had his stage 2 installed on his ION who i let drive my car,
"FUC#, i just wasted almost a 1000.00 on this slow a$$ stage kit" He doesn't like how the timing drops off after shifts and makes the car "feel" sluggish. He isn't after the max, just something better.
To each his own It's not a big deal, i'm just trying to understand the logic
Old May 21, 2006 | 09:52 AM
  #137
there isnt that much difference between intesnse and gm except tuning and pulley sizes and injectors on the larger kits, at least someone can go up to them if they want, some people are happy with the stages some want more, its an individual thing.
I for one want the stage to start and will go from there, I have the supporting mods to support whatever I want.
at least getting a vendor to have the ability to make gm hubbed rings is a bonus for all with the stg 2 kits
Old May 21, 2006 | 09:54 AM
  #138
i'm sure also that if intense and GTP develop a stage 2+ flash that works with the gm stage kit and removes those negatives from the gm flash that would be a good deal for others...
Old May 22, 2006 | 02:53 AM
  #139
Let me know how this goes. I may be interested after a while. For now GMPP Header and Corsa touring are on order. I hope to get around 255 HP or so to the wheels before the
2.8"
Old May 22, 2006 | 02:56 AM
  #140
[QUOTE=FAST06SS]My big question is this,
They have tamper proof bolts on the pulley w/paint to prevent exactly this from happening.QUOTE]
Ya know, I believe this is true. However that is pretty crazy that GM would go to all of this trouble to maintain the warranty. Makes me wonder if GM ever comes out with a warranty stage 3 kit it will have very little to do with the pulley size.
I have my old parts from the 3.0" IF I go with the 2.8" route.
Also I've been reading all over the place the argument that the supercharger is good to 14K RPM as redline and 16K to RPM as redline. Most of the evidence says 16K RPM redline. What then is the smallets pulley that can run on our eaton without going over 16K RMP?
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
SlowSaturn
Sep 28, 2015 11:03 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
