2.8 pulley question
2.8 pulley question
Right now i have stage 2, would it be worth it to go to a 2.8 pulley? would i need to retune the car? could i use the same stage 2 belts? im lookin for a little more acceleration. pros and cons guys! thanks!
2.8
Pros, More power.
Cons, More heat, Shorter engine life, Injectors going static and car stalling the list goes on forever, Some poeple have been fine running a 2.8 on stage 2 other have blown motors doing i it, Problem is the injectors arnt big enough.
If you want to keep you stage 2 tune and everything i would go with a 2.9.
If you really want a 2.8 you will need 60lb injectors, Injector harness, And a retune
Pros, More power.
you dont need a pulley. you need cooling mods and fuel. stage 2 pulley is enough to get you low 13's, with perfect conditions, a 12
im not on 42's and i have other **** done
Last edited by hatrickstu; Jan 12, 2009 at 04:16 PM. Reason: Automerged Doublepost
Listen To hatrickstu, His is currently the fastest stock blower car,
I would do OTT's new heat exchanger, Get some 60lb injectors, 2,8 and a tune.
If you want to leave your GM tune, Then just get a heat exchanger and practice your launches
Driver mod>all
if you go to a 2.8 you will most definately need a retune. BUT!! go with 60lb injectors & wiring harness w/ 2 step colder plugs. a 2.8 pulley will completely max our your 42.5lb injectors and things could go wrong. and then go to Tune Time Performance (i see your in NJ) they are located in Toms River, they can dyno tune you. also you should definately look into getting a heat exchanger, dual pass w/ option b & maybe meth injection. that all together will give you an amazing increase in power, enough to make you crap yourself.
i've got the gmpp sports exhuast, so ur sayin i should go with a header and dp, maybe a head exhanger for now.. and then if i want more power later go with the 60 pound injectors, smaller 2.8 pulley
You got it... Except i would ditch the GMP exhaust and get a CTI 3" if you do the 2.8
for now ill prolly just go header and dp an heat exchanger...nothing too drastic. an i like the gmpp sports exhaust its so deep an mean sounding lol
whats are good brands of header/dp..is the zzt good? i heard haun is good too
Last edited by 2007blacksssc; Jan 12, 2009 at 04:42 PM. Reason: Automerged Doublepost
go to www.ottperformance.com
they are great guys to deal with, get the CTI header/dp combo and they also sell heat exchangers
yes, but a 2.25 exhaust isnt flowing enough for an efficient 2.8 setup
I am actually really glad you said this people i have been doing some research and was scared to do the 3 inch but i have the 2.8 with 3' DP already so...I am gonna go with OTTP Exhaust system
patooyee
Oct 1, 2015 01:07 PM
