2.85 Question!!!
2.85 Question!!!
I have a 2.85 sitting here
Currently:GM stage 1, replacement air filter, 3" pulley, and Colder plugs are what im running.
My main concern:
Is the 2.85 pushing the blower past its limit? Heaton instead of Eaton?
I was going to buy the idler pulley until i recieve my belt, I want to run the S2 belt, its actually on order for me, so that's kinda why im holding off, but I have the itch to throw the 2.85 on.
Is the fueling needs ok? I dont have an aeroforce, so I cant monitor Injector pulse widths or anything... I was mainly just planning on running the 2.85 once and a while, otherwise im happy with performance from the 3.0
Just want some opinions, Thanks
My main concern:
You're fine with the 2.85". Fuel will be good, you're not shoving too much heat, from everything I've seen-a 2.8" pulley is just fine with those mods. If you want to see a Heaton, put a 2.5" on! Holy cow! It would benefit you to get a header or atleast a cat-back to help get the air out faster. If you don't have emissions testing, definitely get rid of the cat, that's a huge restriction. Have fun.
Iceberg
Sep 29, 2015 12:33 PM
