2.9 and 140% IDC... Oy...
Old Jul 19, 2009 | 12:01 AM
NexTnmE's Avatar
So I didn't even get to tune again because the guys at the shop said that 140% IDC is not good no way?!?!? I had my Stage II setup tuned last year, but then got a 2.9" and finally got back to the tuner, and bad news I'm going to get 60's (in the mail), but I was thinking while I'm at it, why not go down a pulley size or two? Is 2.7" too small? I've heard good and bad about the 2.7 unless you have some serious cooling mods... thoughts?
Old Jul 19, 2009 | 12:09 AM
KillerBee's Avatar
With a 2.7 you should have a bigger or extra h/e. You can run the 2.7 with 60s without maxing out your injectors.
Old Jul 19, 2009 | 12:10 AM
Mattman6's Avatar
get cooling mods or stay with a 2.9
Old Jul 19, 2009 | 12:12 AM
Mattman6's Avatar
Old Jul 19, 2009 | 12:30 AM
NexTnmE's Avatar
That's what I thought. Bigger heat exchanger. Most practical next step. Good thing summer days are nice to work on the ride!
Old Jul 19, 2009 | 12:32 AM
Zach06CobaltSC's Avatar
I would go with a 2.8 personally. If you go lower then that you are putting the blower out of its efficiency range. I would also look into meth injection.
Old Jul 19, 2009 | 12:44 AM
NexTnmE's Avatar
if i just put the 60's on, and tune with the 2.9, do you think i'd see an increase in hp? or just keep the same levels, but not be maxing out the injectors?
Old Jul 19, 2009 | 12:45 AM
BLAZIN07SS's Avatar
I'm too JDM for you
depends on how much timing and what AFR's your previous tuner put in
Jan 12, 2016 12:01 AM
TurboTechRacing
Oct 27, 2015 07:58 AM
Turbo6
Sep 30, 2015 09:14 AM
Sep 27, 2015 08:53 PM
medic710
Sep 6, 2015 08:53 PM
