2.9?
I've had a 2.9" on my car with the GMS2 tune for a year and a half with no cooling mods and have had zero issues with it. I just added a h/e a few weeks ago to start preparing for some new stuff
Just remember, you can never have too many cooling mods. If you're at all paranoid about it, just throw a h/e on there.
it's worth it.
Some people will come in and say 42lb/hr injectors are fine, no they're not. Get 60's
I would suggest dual pass in addition to your front mount. Other than that and a tune i'd say you're set.
An exhaust would only help.
But arent they alott of money? Dont know anything about them.
x2 to basically all of that. I think the GMS2 tune is conservative enough that you wont have to worry about the injectors (42s) going static or anything. I haven't had any issues with mine.
How much of a difference did you notice going from the stage 2 pully to a 2.9 ?
You can also tune just to get the most from your car. Little things like advance timing or more accurately stay within the optimum AFR range.
i got a 2.85 pretty much the same as 2.9 and im runnin 130% injector duty, which is bad, its gettin fuel cut at top end, and it ran really lean with the stock st 2 tune with a cai and cat back, so id say get a tune, i did drive it as is for a year, but just now noticed how close to death i was, not too happy about that,,
Last edited by 06Stage2Cobalt; Jan 21, 2010 at 12:20 PM. Reason: accidentally typed 2.5in pulley, should be 2.85
Yeah, if you tune for the 2.9 on 42's you will reduce your IDC's. but they will still not be at a "safe" operating level.
Like I said, I ran the GMS2 tune with 2.9 FOREVER. And had no issues. Car ran strong as hell too.
Injectors are considered "maxed out" at 80%. My IDC's were 122% at 7300 rpm with GMS2 on 2.9. Just to give you a figure.
why would you get your limiter raised and not get tuned? lol
but yeah thats what i was thinking since the s2 tune commands in the tens past 4300 (i think) that leaning
out the tune to say 11.6-11.8 would give the injectors a little more room to breath (or pulse lol) than the s2 tune
I was effing around with the car.
I leaned it out to 11.9
My IDC's now are 74% with the TVS, 3.1 pulley and meth. (60's). So they're pretty much as far as they can go.
GM tune commands low 10's. First time I got on it after putting in my AEM WB it pegged at 10.0
what year GM Stage Tune did you have when you pegged a 10.0 AFR?? I know the earlier tunes for the 05's & 06's ran pig rich. When I was running my 07' GM Stage Tune it had a command AFR of 10.8.
