2.9 Pulley change
Old May 18, 2008 | 06:25 PM
jvc06sc's Avatar
2.9 Pulley change
I have the gm stage 2 and im swapping the pulley out for a 2.9. I was just wondering if you need to mess with the tension when you do this or is it fine how it is
Old May 18, 2008 | 06:38 PM
07 SS/SC's Avatar
You should be just fine, no need to adjust anything.
Old May 18, 2008 | 06:41 PM
schamsy's Avatar
what about a 2.85 on a stock SS/SC. Is it fine to run?
Old May 18, 2008 | 06:44 PM
Super_SS's Avatar
stick with the 2.9
Old May 18, 2008 | 06:47 PM
rockkrawler628's Avatar
wow.....
Old May 18, 2008 | 06:50 PM
NamedGobalt's Avatar
no.. no it's not, you need injectors and you might need an adjustable tensioner. You will also need a tune.
Old May 18, 2008 | 11:31 PM
schamsy's Avatar
Sorry, haha I meant stage 2 not stock... my bad
Old May 18, 2008 | 11:33 PM
cobaltssTH's Avatar
cooling mods!
Old May 19, 2008 | 08:04 PM
Littlegoose's Avatar
Agreed. Many people will say they've run the 2.85" fine on the S2 tune, but keep in mind it's a canned tune. It's not specific to your car and it's always recommended to get a tune especially when changing pulley sizes because that's a relatively big change in incoming air. A 2.9 is what most will say is best/safest to run on the S2 tune if you don't plan to get a tune soon, including Nate.
Old Dec 27, 2008 | 05:47 PM
jonnymerk's Avatar
-bump-
do you need to take the sc off in order to swap from the s2 pulley to the 2.9?
Old Dec 27, 2008 | 05:55 PM
scott allen's Avatar
pulley
i got a 2.79 on my stage 2 set up the belt does not slip at all.its running 17.5 lbs of boost.however it does not run smooth wot.it misses a little when i get on it,got to get tune
yes it is a lot easier,if you dont you will most likely strip the pulley bolts
Last edited by scott allen; Dec 27, 2008 at 05:55 PM. Reason: Automerged Doublepost
Old Dec 27, 2008 | 06:23 PM
mcphatty's Avatar
if you're running stage 2, you shouldnt need the tensioner. the stage 2 belt is smaller than stock so you should be fine.
somebody correct me if i'm wrong.
but definatley get a tune, stage 2 tune is notorious for being complete ****
Old Dec 27, 2008 | 06:31 PM
Snakes709's Avatar
if he has stage 2 already he should have the shorter belt. if u go to 2.9 that should be it....nothing else required. If you go to 2.8 you need 60lb injectors and a tune. Cooling mods are NOT required but it doesnt hurt to have them
Old Dec 28, 2008 | 12:57 AM
flash13brandon's Avatar
The stage 2 pulley is a PIA to get off because you have to use an impact so I would say Yes to taking off the sc when swapping to the 2.9...
Old Dec 28, 2008 | 09:23 AM
mcphatty's Avatar
i would recommend against using an impact wrench- i used one when trying to get my pulley off, and the threads on the pulley puller ended up getting stripped. just be patient and do it by hand with the pulley puller.
and yes, you have to remove the supercharger to do this.
Old Dec 28, 2008 | 10:42 AM
Pulley puller?? You just use the stage 2 bit they give you with the GM Stage 2 kit...and combine it with a hand impact and that's how you get it off...
Old Dec 28, 2008 | 10:56 AM
Zach06CobaltSC's Avatar
I absolutely hate these threads. Let me settle this for you real quick. Do you like starving your motor of fuel? Do you like running your injectors static to the point where they could seize? If not, don't use small pulleys on a rich crappy stage 2 tune. The lowest pulley you should use IMO is a 3.0inch pulley. Running a stage 2 and 2.9inch pulley I have seen IDC's injector duty cycles over 110% at 7grand. You want your idc's to be no higher then 80%. Anyone who thinks they can get away with a 2.79 or a 2.8 is just an idiot. I'm sorry but you should NOT starve your motor of fuel like that man. Get some bigger injectors, there not that much.
www.ottperformance.com great deal on stage 1 kits and or just 60lbers. GET THEM.
Old Dec 28, 2008 | 11:19 AM
Snakes709's Avatar
I have 2.8 on my car and it runs amazing. IDC is low and everything is running good.
Old Dec 28, 2008 | 11:42 AM
That is because you have 60s...he was talking about running a small pulley on 42s...
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
