2.9 pulley with GM stage 2, reliable?
Old Aug 9, 2009 | 01:36 PM
rukkee's Avatar
I ran a GM stage 3 pulley 2.99 just to be safe, I felt a true 2.90 was too much on the injectors . Going from the stg2 3.06 to 2.99 isn't huge but it was noticable. The car would boost quicker at low RPM as well as giving it 1-1.5 PSI by 7K .
Gm stated it was safe to run on the 42 lber's in the stage 3 FAQ .....i didn't have any issues in the 3 years i ran it. People will say it's not worth it or a waste but i bet none of them have tried it for themselves .
Old Aug 9, 2009 | 11:06 PM
JimHarr18's Avatar
i did try it for myself. was unsafe in my case, tested on a dyno by an experienced tuner/mechanic. which is why i suggest, if you want to try it, check things out on a dyno.
Old Aug 10, 2009 | 12:14 AM
NOLAGSS's Avatar
i just went to a 2.9 today with 42,s. while logging my injector duty cycle was at 105% at 6700 when i hit a fuel cut..
Old Aug 10, 2009 | 01:14 AM
G85 SS's Avatar
Those IDC's seem low. Are you tuned? That would make sense because GM Stage 2 is like a 10.0 AFR. If it has been leaned out to 11.6 or so I could see why your IDC's are that much lower.
Old Aug 10, 2009 | 06:06 AM
rukkee's Avatar
A 2.99 stage 3 pulley ? or a true 2.9?
I was fine on a 2.99 ,but maybe it's because I'm at 1500ft and your at sea level?
Old Aug 10, 2009 | 07:09 AM
im at sea level and i personally maxed out my 42s on a 2.9 at about 5,500 rpms. Upgraded to 60s and was fine.
Old Aug 10, 2009 | 07:13 AM
Staged07SS's Avatar
Administrator
Administrator
i did the same as you, and i fully agree with your statement !! my car has been running excellent on the GM Stage 3 pulley.
Old Aug 10, 2009 | 07:58 AM
QuickSilver_SS's Avatar
This is also the route im going to follow as well to be on the safer side of things. A just feel that a true 2.9" pulley will be to hard on the 42's. I'm also going to install a dual pass end plate to go along with my second heat exchanger.
Old Aug 10, 2009 | 12:43 PM
JimHarr18's Avatar
i had an actual 2.9 on, not a stage 3 2.99. i did a baseline dyno run before i got tuned with 60's, a 2.75, and cooling, and on the stage 2 tune, the 2.9 was not safe on my car, way too lean on the low end.
Old Aug 10, 2009 | 12:52 PM
rukkee's Avatar
Ahh... I was talking about a 2.99 . I didn't go with a true 2.9 because i felt it was unsafe. I think we got our pulley's mixed up. I was advising against 2.9's with 42's .
Old Aug 10, 2009 | 01:15 PM
  #36
Jn2's Avatar
Jn2
hmm...weird i wondering why u guys cars are maxing out on 2.9's, i could see elevations being why, but people in diffrence ends of the country are maxxing...here there is a trifecta tuned 2.2sc on 2.8" running 42's at 86%idc's, mine is on a 3.0 and it @84%...both our a/f's are pretty perfect...11.5-12...
Old Aug 10, 2009 | 07:25 PM
  #37
Gene Culley's Avatar
Talking
Yeah, that is weird. My 2.2 is at 76% on the 2.9 pulley.
Old Aug 11, 2009 | 01:48 AM
  #38
compucarnut's Avatar
been on a 2.9 with stg2 for over a year now. occasional WOT blasts and variety of weather. Motor hasn't even as much as pulled an engine light.........
Old Aug 11, 2009 | 02:41 AM
  #39
rukkee's Avatar
GM stage Tunes........That should explain it lol/
Old Aug 11, 2009 | 07:24 PM
  #40
Talking
No Stage 2 tune for a 2009 Pontiac G5 GT man... Trifecta tuned.
Old Aug 11, 2009 | 11:41 PM
  #41
rukkee's Avatar
I was responding to the question of why other people have high IDC's compared to the 2.2 guys..........It's cause of the GM stage tune others are running lol.
Old Aug 12, 2009 | 06:56 PM
  #42
Talking
Oh yeah, I totally agree on that one
Old Aug 29, 2009 | 11:50 PM
  #43
DerfSS's Avatar
To summarize guys, should I go with 2.99, stage 3 pulley, and cooling mods or stay stage II ?
Old Aug 30, 2009 | 08:12 AM
  #44
2.99 and a second heat exchanger !
Old Aug 30, 2009 | 08:21 AM
  #45
screw the second heat exchanger, just replace the stock one
thats because it wouldnt pull an engine light, it would just start running lean up top and cutting out.
Last edited by 07MetallicSC; Aug 30, 2009 at 08:21 AM. Reason: Automerged Doublepost
Old Aug 30, 2009 | 06:58 PM
  #46
DerfSS's Avatar
What is the best remplacement heat exchanger can I put on ? The ZZP's one ?
Old Aug 30, 2009 | 10:48 PM
  #47
Talking
Most argue OTTP or ZZP and I used the ZZP.
Old Aug 30, 2009 | 11:57 PM
  #48
DerfSS's Avatar
You also put the "option B" or only the heat exchanger itself ?
Old Aug 31, 2009 | 12:00 AM
  #49
SuperSport4's Avatar
ull be fine..... i see ppl do stg2 tune with 2.8 all day... no prob....
Old Aug 31, 2009 | 09:30 AM
  #50
JimHarr18's Avatar
i'd get a dual pass endplate before a replacement OR second heat exchanger. it's my understanding the endplate alone helps out a lot. with a 2.75" pulley, and both a 2nd heat exchanger and dual pass endplate, my intake temps, on the 5th dyno pull, were 120. cooling mods are underrated and often overlooked with forced induction cars. get the 2.99 and a dual pass!
