2 step colder plugs??/
Old Feb 1, 2006 | 11:25 AM
06black's Avatar
what is a good plug that is 2 steps colder than stock
is there an ngk-bkr-8e??
any manufac will be fine...just need 2 steps colder
Old Feb 1, 2006 | 01:31 PM
06black's Avatar
out of all the people whith pulley nobody has gone 2 steps colder?
Old Feb 1, 2006 | 02:08 PM
max_boost's Avatar
No there isn't an ngk-bkr-8e. There is a thread over at the Redline forums where a guy is looking for the same thing you are. He tried a two step colder NGK Iridium plug but got more knock with that plug than the bkr-7e. I assume you are having the same problem.
http://www.redline forums.com/forums/sparkplugs-com/8155-2-stage-colder-copper-plug.html?highlight=colder
Old Feb 1, 2006 | 02:33 PM
1stbluSS's Avatar
jmc007 went two steps colder and he said it made his engine knock something terrible. He is running a 2.7 sooooooo.................
Old Feb 1, 2006 | 07:55 PM
06black's Avatar
so going that much colder made more knock????
how the **** is that possible????
i need to drop down that much to make up for the pulley
Old Feb 1, 2006 | 07:59 PM
max_boost's Avatar
It wasn't that it was a 2 range colder plug that cause the knock it was because it was an Iridium plug. But NGK only makes a two ranger colder plug in an Iridium. Maybe Autolite makes one.
Old Feb 1, 2006 | 08:16 PM
Jmc007's Avatar
Going two step colder won't make more knock. The problem I experimented is : Since I run a 2.6" pulley and my timing wasn't optimised, it was causing a lot of knock. In top of that I tried some Denso Iridium Plugs; these plugs requires less energy to spark, causing even more knock because of the unoptimised timing.
Old Feb 1, 2006 | 08:17 PM
Jmc007's Avatar
BKR7E plugs are fine for your current setup as view in your sig.
Old Feb 2, 2006 | 12:11 AM
06black's Avatar
good to hear
tomorrow i'm hookin up the tech2 and goin for a long ride in my car than swapin in to Gcham05silverredline's car....gonna log as much as we can....see when the fuel inrichment kicks in and check knock and timeing advance....gonna see what rpms we have good and bad things happenin at.
Old Feb 2, 2006 | 12:29 AM
max_boost's Avatar
good to hear
I was thinking about getting an AeroForce Interceptor gauge to do that. Have you thought about that?
Old Feb 2, 2006 | 12:40 AM
06black's Avatar
when i can get my hands on a gage piller i'll get one but for now the TECH2 is crazy accerit and reads EVERY thing....its a dam good tool to moniter things with
Old Feb 3, 2006 | 05:20 PM
max_boost's Avatar
How did your data logging sessions go? Also, did G Cham log with his 3.15" or 2.9" pulley and what were his results?
Old Feb 3, 2006 | 07:15 PM
06black's Avatar
doing the data log went very very well we saw some excelent numbers.....we loged G-cham at the 3.1 and mine at the 2.9 both our cars have the same stuff on them....same plugs as well and we never saw ANY!!! knock....0 the whole time the spark advance got down to about 19 a few times for me but thats still about the 15that we were warned about.
the car is pretty maxed at a 2.9/2.8 at least in my eyes
Old Feb 3, 2006 | 07:22 PM
max_boost's Avatar
Great to hear. That makes me feel good about putting my 3.15 on without anything else. I went ahead and ordered the Interceptor so that I could keep an eye on things. Now I just got to find time to get the pulley installed.
Old Feb 4, 2006 | 10:12 AM
1stbluSS's Avatar
How is GCHAM doing ? I haven't heard much from him on the redline forums. I am running a 3.15 from billetflow without any supporting mods and I have no trouble at all. The car runs awesome. But just because I like to have the latest and greatest I bought the NGK BKR7E OR WHATEVER THE MODEL NUMBER IS. I will put those on when the damn rain goes away. Also I think I will be dropping to the 3" Pulley since it seems like our fuel injectors can take it. I see consistently 14.5 lbs psi in my car with a 3.15 even though at billetflow they have it marked as 14 for this pulley. Dunno maybe my car is a freak but I doubt it.
Old Feb 4, 2006 | 12:55 PM
Jmc007's Avatar
What plug gap guys do you run ?
Old Feb 4, 2006 | 01:17 PM
1stbluSS's Avatar
they are supposed to be gapped at 32 mm right ? This I need to know before I go putting my plugs in.
Old Feb 4, 2006 | 02:00 PM
Jmc007's Avatar
Not 32 mm but maybe 0,032" (inches).
Old Feb 4, 2006 | 02:32 PM
silverSS's Avatar
0.035 same thing pretty much
Old Feb 4, 2006 | 02:33 PM
silverSS's Avatar
what kind of plugs are the NGK BKR7E? are they copper or what?
Old Feb 4, 2006 | 02:44 PM
max_boost's Avatar
Yes they are copper.
Old Feb 4, 2006 | 10:33 PM
06black's Avatar
i gap the plugs rite around the .35mark....a lil less if i cant get it rite on
Old Feb 4, 2006 | 10:34 PM
06black's Avatar
g-babby is doin good he droped down to a 2.9 after i did because he was tired of being SLOW!
if you go much smaller you might want to think about the plugs.....like i said with g-babby and my set up non of us saw any knock....lil fyi
Old Feb 4, 2006 | 10:37 PM
06black's Avatar
the 3.1 is ok...the 2.9 is AWESOME and the 2.7 is a god send!!!! i've tryed all of them and i craped my pants with the 2.7
i'll install my intercepter gage once i can get a good piller mount....but the TECH2 doesnt lie and thats what we used so i'm very confident with my current setup...but in about a month or so things will change a huge amount....just you waite
Old Feb 4, 2006 | 10:47 PM
1stbluSS's Avatar
So the 2.9 doesn't run you too lean ? I would think at 3" our injectors would be maxed out. I went to put my NGK plugs in today and then the snow storm came.......
