210lb/hr Injectors Will they Work
Old Dec 8, 2010 | 04:54 PM
coopercharge's Avatar
I have found a set of bosch high impedance injectors that push out 210lb per hour and are high impedance injectors. Wondering if they may work.
Maybe a better solution for e-85
210lb/hour Bosch Fuel Injector with Denso Connector [0280158821] - $169.99 : EFI Components!, Fuel, Forced Induction, Engines and More!!!
Heres the link maybe some of the tuners can jump in and put forth some knowledge on this.
Old Dec 8, 2010 | 05:00 PM
SCcobaltSS's Avatar
Holy lord those are massive.
I dont think you would be able to get those to idle, some people have trouble getting 80's to idle. They are like 230lb/hr on our fuel pressure. (Didnt do math, just threw a number out there)
Old Dec 8, 2010 | 05:08 PM
Frew's Avatar
Why exactly do you need this much fuel? You wouldn't need this much if you were on a 2.5 on a tvs with e
Old Dec 8, 2010 | 05:49 PM
PenguinPIE's Avatar
not sure if our fuel pump can keep up with that...
Old Dec 8, 2010 | 07:29 PM
selfinfliction's Avatar
why stop that small? get some 440lb/hr injectors like all of the cool kids have
Old Dec 9, 2010 | 01:35 AM
SCcobaltSS's Avatar
Is that good for 4006 HP?
Old Dec 9, 2010 | 01:43 AM
Supercharged06's Avatar
4012hp dont sell them short
Old Dec 9, 2010 | 01:47 AM
b00sted06ss's Avatar
Old Dec 9, 2010 | 02:12 AM
Tundraboarder666's Avatar
Holy **** *****... Good luck trying to idle.
Old Dec 9, 2010 | 05:52 AM
almost, you have to add a single 16lb/hr injector in addition to the 440's right after the MAF to hit those levels
Old Dec 9, 2010 | 08:58 AM
Just a discussion is all not looking at doing anything at the moment just a discussion.
Old Dec 9, 2010 | 09:26 AM
RoadconeTuning's Avatar
those are good for like 850-900hp on E85... a LOT of evo guys are maxing out the FIC 1050's in the 400hp range on E85... those injectors will idle like stock as well if its the new high impedence stuff that the Injector Dynamics and EFIWizard stuff is...
Old Dec 9, 2010 | 09:36 AM
Dirty25RS's Avatar
My evo has 220# injectors on E85 by injector dynamics. I believe they are the same base injector as this but modified.
One thing to note is that you'll need a 1.024ms minimum injector pulsewidth in order to idle properly. Even lower on pump gas.
It will have a hard time hitting stoich when in closed loop at idle.
Let me know if u have. Any questions as I have a lot of experience with this type of application.
Didn't really read any of the replies.
Old Dec 9, 2010 | 09:40 AM
Phyrric's Avatar
I think those would drain your gas tank faster then gas station pump flows
Old Dec 9, 2010 | 09:43 AM
Dirty25RS's Avatar
My Evo has 3 255lph walbros and I'm running 50psi base fuel pressure to keep up.
Though there are other ways to climb the mountain than giant injectors.....
Old Dec 9, 2010 | 11:55 AM
SCcobaltSS's Avatar
This
Old Dec 9, 2010 | 12:13 PM
2.2 gallons per minute at WOT lol
Old Dec 9, 2010 | 12:21 PM
Dirty25RS's Avatar
Well maybe not at WOT unless you are running enough boost to necessitate that much fuel.
If you were flowing enough air to match the max fuel flow of these injectors at base fuel pressure that'd be 75% more fuel flow than a bughatti veyron at full clip. So given equivalent bsfc you'd expect around 1750bhp.
Old Dec 9, 2010 | 12:27 PM
ecot3c inside's Avatar
so, you would want this if you were triple charged? 1 small turbo on each 2 exhaust ports (2 turbos) while still keeping the supercharger with a 2.6" pulley running around 34 psi?
I bet I can make them idle on my car though..... my mpw would be fairly high though
Old Dec 9, 2010 | 02:35 PM
Dirty25RS's Avatar
On a 3076R @ 34psi I'm at 65% duty cycle on the 220# injectors.
Why would your min ipw be high?
Old Dec 9, 2010 | 02:38 PM
SCcobaltSS's Avatar
I thought you can only fit two walbros in your tank?
Dont be so sure of that.
He thinks that is what is going to make his car idle...
Old Dec 9, 2010 | 02:46 PM
elite_Cyborg's Avatar
On a s259et and 25 psi I was only about 70 idc with a 42lb bar pressure. I doubt you should get a stock ecu to control those
I already played around so much with my #80s and the only thing that would make them idle perfect was increasing the mpw from 0 (like most of you use) to 4.00, messing with the injector fuel table would not help. I prefer to keep the injector table like it should be per the spread sheet and not decrease it. Highest IDC ive seen was maybe 55% at WOT.
Old Dec 9, 2010 | 02:50 PM
SCcobaltSS's Avatar
We are talking minimum pulse width not short pulse limit...
Old Dec 9, 2010 | 02:52 PM
Dirty25RS's Avatar
My fuel systems a little more elaborate than you are imaging.
All a high min ipw is gonna do is make the car idle pig rich and foul plugs and plug cats unless you wanna idle at 3krpm.
