250whp
Old Jul 11, 2008 | 08:17 PM
dylaNNN's Avatar
250whp
so... with the mods in my sig i put down 243whp and 225tq... what other mods that arent really expensive would put me at the 250whp goal? i was thinking of going with a devils own kit, but mother doesnt seem to approve... for some reason when i told her meth injection she flipped out lol... any suggestions?
Old Jul 11, 2008 | 08:18 PM
Zach06CobaltSC's Avatar
are you trying to do this on 42lbers?
Old Jul 11, 2008 | 08:20 PM
dylaNNN's Avatar
ill end up putting 60's in when i get more cash... but if the 42s could make it then thatd be cool haha
Kibosh3's Avatar
meth injection and better tune
Old Jul 11, 2008 | 08:22 PM
well if you are on the stage 2 tune now, I recommend going with 60lbers and a 2.8inch and a tune. A tune alone would get you to 250, on the dyno you are using.
But methanol injection is the safest mod for your car. Just so you know. Meth injection will lower your temps at wot somewhat, and will allow you to run more timing.
dylaNNN's Avatar
another problem with meth is that im going off to college 4 hrs away from here in the middle of nowhere, and i highly doubt i can buy methanol up there... ill have to come home to get some unless i get a big ass tank in my trunk... but then where will my hockey bag go?
Old Jul 11, 2008 | 08:23 PM
brett5's Avatar
i 've seen charts on here that a bigger pulley will work better with your set up till you get a better tune
Old Jul 11, 2008 | 08:25 PM
dylaNNN's Avatar
yeah i know... joe suggested getting meth and it will give him more timing to give me more power... if i get the meth am i going to need to get the 60's? and he quoted me $600 for a basic devils own kit, install, and dyno time to retune it... think thats a decent price?
Old Jul 11, 2008 | 08:39 PM
brett5's Avatar
as far as i know you need 60s
yea but if all your looking for is 250 you can easily get that with a better tune and the right size pulley....now that i think of it that rallicobalt guy..i think he said he was running meth on 42s so maybe
you can use winsheild wiper fluid
Old Jul 11, 2008 | 08:40 PM
dylaNNN's Avatar
yeah i just read that on the other thread... 250whp is what i wanted to get for the car... but a little more wouldnt hurt...
yeah i heard about that... certain ones have different methanol/water ratios or some ****
Old Jul 11, 2008 | 08:49 PM
brandondrecksage's Avatar
just go to a higher reading dyno...lol.
Old Jul 11, 2008 | 08:50 PM
.....methanol is just windshield wiper fluid. Thats almost a 50/50mix too. Just simply buy windshield wiper fluid -20f. Then add a bottle of HEET. You can find these anywhere in the world. Gas stations, autozone, walmart, anywhere.
You want a 50/50mix and you don't need a tune to run it, however you will benefit from a tune.
Old Jul 11, 2008 | 08:55 PM
brett5's Avatar
are you sure i was always told you needed a tune to run the meth kits??? thats the only think from keeping me from gettting one
Old Jul 11, 2008 | 09:07 PM
I am running my aem methanol kit untuned right now.
The point of running meth untuned is to have lower iat2 temps, basically to keep the car cooler, which is why you don't even need methanol at this point. You could and should run straight distilled water.
When you are tuned, run a 50/50 mix of methanol and distilled water and you will be able to increase your timing. The methanol is an increase in octane. Its like having 120 octane gas instead of 93 pump gas.
You do not need a tune to run methanol. Trust me as I and others are doing it now.
Old Jul 11, 2008 | 09:10 PM
brett5's Avatar
ok cool but if i run just water with out a tune what would happen in the winter
Old Jul 11, 2008 | 09:15 PM
Jimmys2007CobaltSS/C's Avatar
those sounds weak..shouldn't ya gotten more out of that
Old Jul 11, 2008 | 09:19 PM
XM15's Avatar
Just tell her you are injecting it into the car, not your arm. lol
Old Jul 11, 2008 | 09:45 PM
his numbers are pretty spot on, just depends on the dyno. In the winter, depending on how cold it gets in your trunk, the water could freeze so keep an eye out for that. Make sure its distilled water.
Old Jul 11, 2008 | 10:09 PM
CobaltSS 16's Avatar
Get 60s, 2.8 pulley, tune, and cooling mods... and you should hit your goal pretty easily granted it's on the same dyno.
Old Jul 11, 2008 | 10:37 PM
dylaNNN's Avatar
well the winter ill be pretty damn close to iowa... until christmas break... idk how cold Kirksville, MO gets but id imagine colder than STL lol.. i want to install the devils own kit but i need to make sure its reliable... i read about meth and it said its flammable but not as much as gas, which is a plus lol... i just dont think that im going to be able to sell the car down the road with meth and **** on it... its gonna be hard to find a buyer unles i take it off and ****... idk if the type of dyno matters, but it was done on a dynojet... would a bigger heat exchanger and injectors and a smaller pulley put me in a closer range to the 250? what are some other alternatives to hitting or going passed 250whp without meth and nitrous?
Old Jul 11, 2008 | 11:42 PM
restonSS's Avatar
cxracing heat exchanger, 2.8, 60's and you will be there no prob.
oh and a tune of course
Old Jul 11, 2008 | 11:56 PM
AjSS's Avatar
Pretty much, I use a gallon of -20* and 2 bottles of Heet. Heet is like 98% methenol, and the washer fluid has about 25~30% methenol, and the rest is mostly water. Just dont use washer fluids with additives in it.
no.
Its more like 105-115 tops, depend alot on your mixture.
But you are right that you dont have to tune for it, but you will gain more if you do.
Old Jul 12, 2008 | 01:18 PM
mrniceguy8211's Avatar
But does this work with the 100 octane mode in the stage 3 computer??
Old Jul 12, 2008 | 03:16 PM
TheLaxPlayer's Avatar
If you don't tune for the methanol, you can just disconnect it for the winter and keep the tank empty.
Old Jul 12, 2008 | 05:34 PM
h0l0caust's Avatar
your mom or YOU is paying for this ****, if its you, tell your mom to go play bingo.
