3.0 Pulley
Old Apr 10, 2006 | 09:12 AM
Slam's Avatar
3.0 Pulley
Anyone running a 3.0 without larger fuel injectors? If so, any issues on the a/f ratio?
Old Apr 10, 2006 | 09:20 AM
silverSS's Avatar
Yeah, on stage 1 reflash . No issues
Old Apr 10, 2006 | 10:12 AM
freakaccident's Avatar
I am running one with no problems. Just have one step colder spark plugs.
Old Apr 10, 2006 | 10:13 AM
astrocrep's Avatar
You have just the flash or the whole stage1 kit?
Old Apr 10, 2006 | 10:21 AM
Slam's Avatar
What model plugs you running?
Old Apr 10, 2006 | 12:31 PM
NGK bkr7e
Old Apr 10, 2006 | 12:39 PM
silverSS's Avatar
You can run the NGK BKR7E with the 3inch pulley on the stock car with no problem. No belt slip, no EM needed...although my car with the S1 reflash made it run even better.
Old Apr 10, 2006 | 12:58 PM
Mines_Better's Avatar
nothing here...
Old Apr 10, 2006 | 01:03 PM
Slam's Avatar
I'm trying to figure out what the smallest pulley I can run is, with just adding colder plugs, and nothing else. Don't want it to be borderline problem/cels etc. Just want the most power without having to install bigger injectors, or jack with changing the a/f programming.
Old Apr 10, 2006 | 01:04 PM
c7015's Avatar
^^^ From what I have read 2.9 is the smallest you should go ...but I dont have the data to back that up
Old Apr 10, 2006 | 02:03 PM
That's why I stuck with a 3.0
Old Apr 10, 2006 | 02:04 PM
c7015's Avatar
same ...if thi sUPS garbage ever gets sorted out and it gets here
CC
Old Apr 10, 2006 | 02:22 PM
zinner's Avatar
Moderator Alumni
Stage 1 is larger fuel injectors.
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
