3,0" Pulley Technology pulley, Dyno results !
Old Oct 13, 2005 | 10:29 PM
VaMP's Avatar
Good to hear man, which CIA are you going with?
Old Oct 13, 2005 | 11:10 PM
Jmc007's Avatar
I'll get the Fujita CAI this very friday !
Old Oct 14, 2005 | 12:11 AM
VaMP's Avatar
Great news man! Make sure you let us all know! Document it and be the first to post in howt to about installing an aftermarket intake!
Old Oct 15, 2005 | 10:04 AM
Jmc007's Avatar
About the last paragraph on my first post of this very thread, the dyno loss wasn't cause by the MAF ... I am pretty damn sure it was caused by the by-pass valve selenoid.
Old Nov 4, 2005 | 05:08 PM
Jmc007's Avatar
Fujita intake sold, I will have to add more fuel; not more air.
Old Nov 20, 2005 | 11:57 PM
silverSS's Avatar
can i run the 3inch pully that you got with the stock belt, and stock everything? just swap the pulley?
will i be safe, truthfully?
Old Nov 21, 2005 | 01:06 AM
JCX's Avatar
JCX
12.8 is pretty lean on a forced induction motor, IMO. I'd keep it under 12 for sure either that or add water / meth / alky injection. 15 WHP is not worth a bottom end IMO.
Old Nov 21, 2005 | 06:35 AM
ralliartist's Avatar
Thumbs up
i just wanna say nice numbers and you seem to know what you are talking about!!!!
brad
Old Nov 21, 2005 | 11:04 AM
silverSS's Avatar
anyone?
Old Nov 21, 2005 | 11:30 AM
selfinfliction's Avatar
Originally Posted by silverSS
anyone?
should be fine, if you're worried about it, there's an adjustable pulley tensioner on ebay for like $75 or so that people say is really good
Old Nov 22, 2005 | 04:40 PM
  #36
theBLUEone's Avatar
Are you running any kind of piggy back or anything to control timing? Because, on Southern Pulley Headquarters they state that you cannot run smaller than 3.25 with out timing and fuel alterations....
Old Nov 22, 2005 | 10:56 PM
  #37
Jmc007's Avatar
3" pulley is fine with the stock belt; no slipping at all. Yes you can use it with everything else stock, but it is better ti run it with the boost by-pass selenoid disabled.Po someTearch = find 1e righ1method3o do i
Old Nov 23, 2005 | 12:59 AM
  #38
BlAckOnBLaCK's Avatar
Well I put on my 3 inch pulley and tried running it with the stock belt and it squeaks like hell. I did however get 15psi but I can't stand the noise from the loose belt so I am waiting for the new belt that GM is releasing with the stage 2 kit before I drive it anymore. There are lots of people that are driving it with the stock belt but I am probably the only one that has this problem for right now.
Old Nov 23, 2005 | 12:38 PM
  #39
Jmc007's Avatar
Is your pully 100% aligned with the belt ? Do you get it installed the right side ? Go in my member gallery section to view mine.
Old Nov 23, 2005 | 02:10 PM
  #40
theBLUEone's Avatar
So...I could put a 3" pulley on and I will be safe?
Old Nov 23, 2005 | 08:09 PM
  #41
Jmc007's Avatar
No prob until you doesn't drive your car always past 6000 RPM's lol.
Old Nov 24, 2005 | 01:02 AM
  #42
silverSS's Avatar
what about 6400
Old Nov 24, 2005 | 01:27 AM
  #43
theBLUEone's Avatar
Ok, gotcha..I may just go with this pulley until the staged upgrade kits come out...
Old Dec 6, 2005 | 01:02 PM
  #44
FSRbikr98's Avatar
JMC have you tried putting in higher octane fuel, if so did it make any noticeable difference in the air fuel ratio?
Old Dec 6, 2005 | 01:22 PM
  #45
Jmc007's Avatar
Not yet !
Old Dec 30, 2005 | 01:20 PM
  #46
Jmc007's Avatar
Cobalt SS 3" supercharger pulley ...
https://www.cobaltss.net/forums//showthread.php?t=10281
Thanks !
Oct 20, 2015 09:56 PM
maliki778
Oct 1, 2015 07:39 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
