3.15 w/ NGK BKR7E
Old Apr 6, 2006 | 03:02 PM
Ern's Avatar
Ern
3.15 w/ NGK BKR7E
How does the car respond to this setup? Im thinking just a pulley becuase I have the plugs already and Im curious as to how this setup is without a stage upgrade kit from gm
Old Apr 6, 2006 | 03:05 PM
silverSS's Avatar
it will pullllllllllll a little more
but no, you will see a big diff.
Old Apr 6, 2006 | 03:06 PM
1stbluSS's Avatar
this is what I have you will notice the difference.
Old Apr 6, 2006 | 03:20 PM
Ern's Avatar
Ern
If i had to buy a pulley should I buy from billet flow? I dont really wanna go smaller than the 3.15 too. Are there different types of pullies and will I need a pulley puller?
Old Apr 6, 2006 | 03:23 PM
1stbluSS's Avatar
pulley puller yes.... billetflow definately.... they will rent your their pulley puller for $50... also once an interchangeable is on your car all you need is an alan wrench to change sizes... different types of pullies umm as in brands yes but billetflow is the best IMO
Old Apr 6, 2006 | 03:25 PM
R33P3R007's Avatar
360 L337 User
there is tons of different companies, and you will need to remove the S/C and use a pulley puller for all of them. But personally i would make sure to go with something that has an interchangeable hub system, so you can go to a smaller pully and back with no problems
Old Apr 6, 2006 | 03:36 PM
Ern's Avatar
Ern
I guess my other question is I see you guys do this bypass valve mod. Do i need to do that? Why would I?
Old Apr 6, 2006 | 03:38 PM
1stbluSS's Avatar
you dont have to do it but your boost will get knocked back down to 12.5 psi when you should be boosting more with a smaller pulley....
Old Apr 6, 2006 | 04:37 PM
Ern's Avatar
Ern
Doesnt a smaller pulley build boost alot faster though too? Im interested in boost more quickly more than more boost.
Old Apr 6, 2006 | 04:43 PM
1stbluSS's Avatar
it will build boost more quickly but you also want to be able to get full boost potential for the top of the gears.
Old Apr 6, 2006 | 05:00 PM
max_boost's Avatar
You don't have to do the bypass mod. I haven't done it on my car and you still notice a difference in power. I know a lot of other people are running the bypass mod with no problems but I've never felt comfortable about doing it. The injectors are already maxed with a stock pulley so I didn't want to up the boost (in the upper rpms) and not have enough fuel. Once the GM stage 1 is installed it won't bleed off the boost anymore and the car will have the fuel it needs.
Old Apr 6, 2006 | 05:10 PM
2006ArrivalBlueSS's Avatar
Do you guys recommend changing plugs even after the Stage 1 reflash? or is it only necessary with the smaller pulley without the flash? comments are appreciated
Old Apr 6, 2006 | 05:13 PM
max_boost's Avatar
I wouldn't change the heat range of the plug until you add more boost. What I did, before I had the pulley, was switch the stock platinum plugs for copper ones (NGK BKR6E). It made the car run smoother.
Old Apr 6, 2006 | 05:23 PM
^^^ THANKS!!
Old Apr 6, 2006 | 05:30 PM
mrbelvedere's Avatar
how about a link to billit flow
mrb
Old Apr 6, 2006 | 05:32 PM
max_boost's Avatar
mrb
www.billetflow.com
Old Apr 6, 2006 | 05:45 PM
Ern's Avatar
Ern
I really want the 3.15 to go with my ngks but I also want to see what happens with you and others that have the 3.15 and are getting the stage 1. I want to see if its a good combo.
Old Apr 6, 2006 | 05:47 PM
max_boost's Avatar
It will be a great combo. The 3.15 will give the same amount of boost as the Stage 2 pulley.
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Turbo6
Aug 27, 2015 08:37 PM
NGalaxyTimmyo
How to Guide
75
Jul 4, 2015 10:22 AM
InfiniteEffect
Jul 8, 2006 08:11 PM
SFPH
Jul 2, 2005 09:35 AM
