3.5" TB and spacer
Please refer to post #45 on this thread.
we will try this Thanks
Ok so we have 21 now! so the price will be $49.99
This GB will end on the 11th
Please just log the MAP1 (before SC) at WOT (before and after the new TB) with one of your 3" intake. You'll see if the stock TB is restrictive !
Personnaly, now with a 2.9" pulley (boosting only 12 PSI at Alberta altitude), stock intake with a K&N air flow filter, I get only 0.2 - 0.4 PSI max of restriction from the stock TB, stock intake and high flow filter.
Also, I can remember at see level with a 2.6" pulley boosting around 19 PSI, I was seeing 1,5 PSI restriction with the stock intake and stock filter.
Last edited by Eng@RebelAutoWorxs; Oct 5, 2007 at 11:22 AM. Reason: Automerged Doublepost
i wonder if there would be any tuning needed if you have a stage 2 from gm. if this increases air flow, then instead of getting a 2.9 pulley, you could have this instead with less heat and same amount of power. i might be in depending how testing on the stage 2 they are testinng goes.
All these vehicles listed, are able to use the 4.2L as a direct bolt on, without modifications.
COLORADO 04-05 Throttle Valve Assm; 3.5L
ENVOY 05 Throttle Valve Assm; 4.2L
TRAILBLAZER 03-05 Throttle Valve Assm; (4.2L)
HUMMER H3 06
BRAVADA 03-04 Throttle Valve Assm; (4.2L)
ENVOY XL 03-05 Throttle Valve Assm; 4.2L
ENVOY 03-04 Throttle Valve Assm; (4.2L)
IMPALA 06 Throttle Valve Assm; 5.3L
ISUZU ASCENDER 03-05 Throttle Valve Assm; 4.2L
GRAND PRIX 05-06 Throttle Valve Assm; 5.3L
ENVOY XUV 04-05 Throttle Valve Assm; 4.2L
TRAILBLAZER EXT 03-06 Throttle Valve Assm; 4.2L
CANYON 04-05 Throttle Valve Assm; 3.5L
MONTE CARLO 06 Throttle Valve Assm; 5.3L
TRAILBLAZER 06 Throttle Valve Assm; 4.2L
RAINIER 04-05 Throttle Valve Assm; 4.2L
SAAB 9-7X 05-06 6 cyl
HUMMER H3 06
What's that...you say a new TB is too much and the local junk yard doesn't have any?? Check out this site:
http://car-part.com/
oops wrong thread i meant to post in the ported intake mani thread. lol reading owns me. lol
