3.5" TB and spacer
3.5" TB and spacer
This GB will expire on the 11th
1. quadracer0387 (intake and blue coupler) PAID
2. Sunburst_SS PAID
3. Toyotech
4. IamTvor PAID
5. joselo6 PAID
6. lsjwannabe
7. Boossted
8. ninja44
9. silentd PAID
11. RedSSBaltSC (black coupler) PAID
12. Coop
13. Rodimus_Prime
14 & 15. r0k0 (with intake no filter) (another spacer with 1/8" npt for meth) PAID *payment for one
16. 607Motorsports PAID
17. my_bd (with black coupler) PAID
18. RG4
19. Freakenhye
20. Hockeyman0920
21. burntorange PAID
22. Jumpin Fool (with intake polished) PAID
23. Stihl (with intake red coupler) PAID
24. SS/SC05/19/05 PAID
25. K-Train04RL (with intake)
26. Omega_5 PAID
27. darksol4life (with intake) PAID
28. Blur.fx (with tap for meth) PAID
29. WolfmanKiknAzz PAID
30. kanabrewski (1 intake 2 spacers with one tapped)
31. SSKobald (2 spacers with on tapped)
32. Dainslaif PAID
33. Beck PAID
While waiting for a new batch of Twin Screws to come in we thought we would test something new.
We took a throttle body off a chevy Colorado 4.2L and using an adapter plate attached it to the stock supercharger. This new TB is 3.5" giving the ability for more air flow.
Results showed 1.5psi increase in boost and 2 lb/hr increase flow through the MAF sensor. We will have dyno results soon. From the butt dyno we can definitely see an increase in the lower end, more of a kick when you stomp on it.
Also we had the throttle hooked up to our full 3" intake all stainless steel and powder coated (this is a good item for anyone who has seen wear marks in their aluminum intake)
The price for the TB Spacer is $100US and $300US for the intake. $389 if you get both.
$49.99 for the spacer with a minimum of 20 people
The spacer will come with:
- Proper notch for the evac line
- a grove with gasket installed so you don't have to play around with messy liquid gasket
- longer stainless steel bolts.
Remember this spacer also provides more area for air to be stored for quicker response.
You will have to purchase your own 3.5" throttle body which you can find at a local wreckers or dealer.
2. Sunburst_SS PAID
3. Toyotech
4. IamTvor PAID
5. joselo6 PAID
6. lsjwannabe
7. Boossted
8. ninja44
9. silentd PAID
12. Coop
13. Rodimus_Prime
18. RG4
19. Freakenhye
20. Hockeyman0920
26. Omega_5 PAID
32. Dainslaif PAID
33. Beck PAID
So if you have a cold air intake already you would have to trim it to work? And would'nt you have to tune the car for a new throttle body? and one last question. This is just a spacer for 100 bucks right?
Looking forward to more information.
sorry guys, yes you have to change the ETC scalar area parameter in the tune. We also found that the Air/Fuel got slightly leaner with the increase in air flow so this would be something to fix aswell. But then again if you are running a GM tune it is rich to start with. The effect of this upgrade is similar to getting a larger intake or exhaust.
We can give you guys a deal on the tune if anyone wants us to change this parameter, the cost will be $50US.
harness is a direct fit
Last edited by Eng@RebelAutoWorxs; Sep 30, 2007 at 06:26 PM. Reason: Automerged Doublepost
you send us your PCM, otherwise we send you one but you would have to get a crank relearn at the dealer
Last edited by Eng@RebelAutoWorxs; Sep 30, 2007 at 06:28 PM. Reason: Automerged Doublepost
yes the spacer is $100 which comes with a gasket
if we get a least 10 people intested we can drop the price to $89.99 for the spacer
Last edited by Eng@RebelAutoWorxs; Sep 30, 2007 at 06:33 PM. Reason: Automerged Doublepost
wouldn't say it would be a complete waste as you still have more area per throttle position. Only testing would confirm this
2.7" pulley
60lb injectors
water injection
Rebel 2.5" downpipe
GMPP cat back
Rebel 3" intake
Before bigger TB: (NOTE: did not log AFR here)
http://www.rebelautoworxs.com/Logs/stock.hpl
After bigger TB: (NOTE: did not change the tune here except for the ETC scalar area parameter, so you can see there was an increase in air flow so it ran leaner and knocked a bit)
http://www.rebelautoworxs.com/Logs/2nd%20gear.hpl
Scanner config we use:
http://www.rebelautoworxs.com/Logs/ROAD%20TUNING.cfg
77mm
Paul...go sd...Fk mafs lol
