3'' pulley
Old May 8, 2006 | 12:55 PM
quick_baltss's Avatar
3'' pulley
Is it okay to run a 3.0'' pulley, not a 3.15'' with stock injectors and upgraded spark plugs.
Old May 8, 2006 | 12:57 PM
StreetDreamz's Avatar
Yup. Been doing it for like 2000 miles now. You can even disable the bypass valve and run like 14 psi without running lean.
Old May 8, 2006 | 05:37 PM
What all is needed to run a 3.0'' pulley besides plugs.
Old May 8, 2006 | 05:40 PM
Shortbus's Avatar
Pulley, plugs, and if your gonna do install yourself a pulley puller.
Old May 8, 2006 | 05:48 PM
So I don't need a belt or anything to keep it from slipping.
Old May 8, 2006 | 06:13 PM
Smokem10's Avatar
I have been running that for a while, and no slip. But have heard after time it will start to slip, so I put a bigger idler pulley on, so hopefully that solved any future slippage. I got a 72mm billtflow idler pulley.
Old May 8, 2006 | 06:21 PM
Thanx for the help guys
Old May 14, 2006 | 11:53 AM
Ern's Avatar
Ern
I didnt think you would need an idler pulley. Ive seen alot of guys with the 3.0 like Tofu and no one has said anything about slippage over time? I could be wrong? I want the 3.0 but I dont wanna have to add anything extra.
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
