3" Pulley for Christmas!! What next?
Old Dec 25, 2007 | 12:05 PM
Element-X's Avatar
I'm stock besides an intake and exhaust and I'm wondering if I can slap this baby on without a tune... Can the computer account for the added boost to an extent? Is it safe? I don't want to run too lean here and chew up a piston.
Sorry if this has been answered over and over again, this search engine leaves something to be desired.
-Ryan
Old Dec 25, 2007 | 12:09 PM
Admiral Jedi's Avatar
You might be able to get away with it, I wouldn't try it though....I DID, but I wouldn't do it again, lol.
Old Dec 25, 2007 | 12:13 PM
Element-X's Avatar
Thanks for the response, I'll have to find a tuner shop around here in CT.
Old Dec 25, 2007 | 12:16 PM
06CobaltssOrange's Avatar
get 42.5lb injectors and a stage 2 tune or a hp tuner stage 2 tune thats tweaked a little . dont just put it on then tune it
Old Dec 25, 2007 | 12:42 PM
Element-X's Avatar
Gotcha, shoulda done some research... just realized that the Stage 2 pulley is 3.06" (77.9mm) So should I just get the Stage 1 upgrade from Crate Engine Depot (this is just the injectors.)
Do I need a smaller belt or can the tensioner pick up the slack?
WAIT A MINUTE!!! this is a 3.25" pulley.... just looked up the part# on summit...
http://store.summitracing.com/partde...5&autoview=sku
Will that be safe?
Just found this site... has a nice size recommendation:
http://www.cobaltperformanceparts.co...ey_System.html
Stock Pulley Size is 3.346"
Stock System can handle the 3.30"
Colder Plugs 3.20"-3.10"
Colder Plugs and larger injectors (42-44lb) with tuning for 3.00-2.90
Colder Plugs and larger injectors (50-65lb) with tuning for 2.80-2.70
Colder Plugs Snout machine and larger injectors (65lb+) with tuning for 2.60 or smaller.
Old Dec 25, 2007 | 01:18 PM
freakta's Avatar
ya ive got a 3.0 pulley and stock injectors, ive also got my car at the shop with 2 cracked pistons. it was tuned but the injectors are so maxed out its not funny dont try it
Old Dec 25, 2007 | 01:26 PM
A 3.25" would be fine, I would think. You're adding another pound-ish of boost
Old Dec 25, 2007 | 01:28 PM
CTSSBowtie's Avatar
Jannetty Racing in Waterbury has HP Tuners for the Balts and have done really good work in the past. I would reccomend them for any tuning. Also they have smaller pulleys in stock and can get other parts for you.
Old Dec 26, 2007 | 12:47 PM
nherbst454's Avatar
Will that be safe?
Hmmm...I don't think I'd trust an aluminum press on pulley based on the fact that aluminum expands quite a bit when it heats up. Also, 83.96 + shipping seems pretty steep for a press-on pulley.
Just my $.02
Nate
Old Jan 2, 2008 | 08:27 PM
Element-X's Avatar
Thanks for all the info guys I'll have to rent the ZZP Puller/Installer and get this puppy installed. Really appreciate the tip about Jannetty Racing, I'll have to go check them out.
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
