315 BHP GMPP 2.0 Ecotec Engine ...
Originally Posted by Jmc007
No No No, closed loop is achieve as soon as the 02 sensor is hot enough, it happens WAY before the coolant temp achieve 180 farenheit degrees.
A lower thermostat will only cause problems. Say you put in a 160 deg. stat. The PCM will set a DTC P0128; engine not reaching thermostat regulated temp. This will shut down A/C, turn on coolant fans on high, SES light will illuminate and possibly go into "Loss of Power mode". So, not a good idea.
Originally Posted by Snowman
hhahaha i have part 4 but i dont knwo how to put it up. I got it all on disk when i was @ sema this past year
patooyee
Oct 1, 2015 01:07 PM
Sep 28, 2015 12:51 PM
