4 psi! Need help! I don't know where to start
I have a 2006 cobalt ss/sc I just bought it from a used car dealer. It only has 4 psi the entire time I get on it. Any process of elimination I could have ? I'm about to order a bypass valve. Any other Ideas? I have an injen intake also. 85,000 miles
hmm..i like seeing all these post right around the same time that I am having a similar issue. is the bypass valve on the supercharger the black circular thing close to the throttle body?
yes it is but you need to diagnose wether it is the the bypass actuator or the solenoid if the solenoid goes bad it will always keep the bypass actuator in a no boost position if the bypass acuator is bad it will have the same symptoms so you need to diagnose which one it is before you spend your money
thanks for the advise...and if I do what you said earlier
..."find the vac line coming from the intake manifold and follow it over to the boost bypass solenoid and unplug the vac line then plug and see if it starts shoving more then 4psi"
and it does start pushing more boost would that tell me its the solenoid or the actuator?
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
Cptnslo
Sep 24, 2015 09:32 AM
twilson380
Sep 14, 2015 10:52 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
