400 wheel horsepower supercharged...
Old 05-16-2009, 05:39 AM
  #301
OneCOLDBIZL272's Avatar
Very true i had half a kit, and i just turned around and sold it to someone else, casue i just forsaw it burning a hole in my pocket. i mainly never wanted to experiance the nitrous blow back/ back fire, and blow my fresh motor, i rather just play it safe.
i should of kept it now that i think of it and use it in a different meathod persay. cyro spray my aftercooler.....
Last edited by OneCOLDBIZL272; 05-16-2009 at 05:39 AM. Reason: Automerged Doublepost
Old 05-17-2009, 03:31 AM
  #302
Deathscythe's Avatar
as of right now, had a bad issue with the camshaft sensor not being properly aligned when my stock cams were re-installed. We started tuning before we got around to checking the alignment of the cams and sensor so all of the tables were screwed up. Either today or tomorrow, my tuner (Joe) is going to place my old tune back on the car (tvs minus the ported head and aftermarket pistons) and rebuild things from there. Car pulls like a freight train now, but the fueling is breaking up around 6500. She doesn't like being pushed to hard past that. I'm also trying to find out where the wall is for the 60's. Oddly enough, the idc's are only around 75% right now, so we're moving along slowly to see where the line stops at.
Old 05-17-2009, 03:58 AM
  #303
Rent me! per hour
Area47's Avatar
double postage
plug gap?
dwell settings?
Old 05-17-2009, 11:01 AM
  #304
neither of those. It was the sensor being 180 degrees out of alignment with the cam. Car wouldn't start for ****, but as soon as that was lined up properly, it fires up everytime.
The break-in for the engine is done, the main thing now is that hp tuners is showing the car pulling like 31 degrees of timing at certain points.
wtf?
I learned about burst knock retard, timing the computer is pulling in anticipation of knock. This is happening because of the tuning done when the cams were out of alignment and pretty much all fo the tables were screwed up. That's why we're having to backtrack.
Old 05-17-2009, 11:27 AM
  #305
WSFrazier's Avatar
That cam sensor is just for starting the motor. It has no affect on drivability or tuning.
Old 05-17-2009, 11:42 AM
  #306
I know that, but there were issues we were trying to compensate for thinking it was a problem with the tuning. Once we figured out that the cam sensor wasn't aligned properly, the car started fine, but I'm seeing retarded amounts of timing being pulled on throttle tip in. That's the direction the witch hunt is going in now. And why were backtracking to the beginning again so there won't be any chasing of tails.
Old 05-17-2009, 11:50 AM
  #307
EatonTVS07's Avatar
click+
Old 05-17-2009, 11:54 AM
  #308
I'm looking to get her on the dyno in the next two weeks. I want to see what the hahn exhaust sounds like at 8k.
Old 05-17-2009, 12:41 PM
  #309
WSFrazier's Avatar
Ok, just letting you know. I ran my car without the sensor for almost a year after I built mine. Just got used to the couple cranks it would take to fire up.
Old 05-17-2009, 12:47 PM
  #310
it's annoying as hell though. it's like the car is having a bad dream and can't wake up.lol
Old 05-17-2009, 12:49 PM
  #311
Not a Sebring
WhiteSSBalt's Avatar
I talked to old Joe about your car the other day. Looking forward to seeing how it does on the dyno.
Old 05-17-2009, 12:55 PM
  #312
it's going to be a monster man. I'm still learning how to drive it again, but it breaks free in first and second without much issue.
Old 05-17-2009, 09:29 PM
  #313
StevesBlack06's Avatar
ya learn something new evey day. call me a newb but i honestly didnt know you didnt need the cam sensor. interesting... best of luck on the dyno. im anxious to see what you put down.
Old 05-17-2009, 09:49 PM
  #314
thanks man. I got a huge comparo that'll be coming up in the next few weeks, and it's likely to make a few manufacturers upset. But it will be beneficial for the cobalt community at the same time.
Old 05-17-2009, 10:04 PM
  #315
right on.. keep us posted. god i cant wait for my build to be done! ur build along w a few others are the only things keepin my head up! haha. if ya get a chance take a peek at my vbgarage and check out my mod list and tell me what you think. holla back at me in a pm or sumthin
Old 05-17-2009, 11:14 PM
  #316
will do man. I'll let you know.
Old 05-18-2009, 01:01 AM
  #317
hey death post up a sheet of your dyno please after you do, im curious of what the power numbers will be after 7,000rpms for i only have at 7,200 so i dont bounch off the rev limit and can hit 7,000 no problems, but im still curious for i left mine at 7,200 for i was told you wont see any gains after that really.but im curious of you numbers, this is my build so i would be in the same ball park
Performance Modifications:
Pistons 10:5.1
Sleeved Block
Built Head
Ported/Polished Head
7,200 Rev Limiter
Custom Balance Shafts Delete(yes delete, theres no factory nore nutral they are gone)
Hardened Oil Pump Gears
ARP Head Studs
ARP Main Studs
Cometic LSJ MLS Head Gasket
Spec Flywheel
Spec Stage 3+ Clutch
GM Stage 2 Belt
ZZP Adjustable Tensioner
Ported Intake Manifold
Ported Supercharger
2.7 Pulley
Custom Stage 2 Hub
Supercharger Coupler
Custom 3" Intake
3.5” Throttle Body off GM 4.2L thaoe
3” Custom Under Axle Exhaust System(i have no clearance issues either i basicly have like zero 2 any ristrition
JBP Vortext Header
OTTP Second Gen Heat Exchanger
Meziere's Aftercooler Pump
Dual Pass Endplate
HKS Oil Catch Can
Fuel Filter
Walbro 255 Fuel Pump
60LB Injectors
NGK Spark Plugs(Same As Time Attack Cobalt)
NS-ll Performance Tires Drag Radials
Stage 2 Axles
Tenzo-R Lowering Springs
Drilled & Slotted Rotors/Ceramic Pads
Trans Mount Bushings/Shimmed
Upper Billet Engine Mount
Polyurethane Control Arm Bushings
Solid Custom Driver Motor Mount
Painted Supercharger/intake manifold and whole motor(Black W/Some Red Accents
Custom Tune Hp/Tuners....
Old 05-18-2009, 01:22 AM
  #318
hungryhip-ccp's Avatar
why you stop at 7200? you can spin 8192 with that set-up all day long... you wont make power that high on the head and cams and you will be over spinning your blower but it would be a lot of fun burring the tach before shifting...
seems you need to go turbo or tvs...
  #319
elecblue06's Avatar
^^^ needz pics of exhaust .. and sound clips of car and .. umm lots of things lol
Old 05-18-2009, 01:28 AM
  #320
I think with the tvs that it will make steady power up until my redline. But the dyno's will be posted.
Old 05-18-2009, 01:31 AM
  #321
ralliartist's Avatar
please do post up the numbers and dont be a bitch like some people.
  #322
should look nice! subscribed for results...
Old 05-18-2009, 01:35 AM
  #323
ralli, I have no shame, but i do believe in this build I have. All numbers will be posted as things move up, and nothing will be fudged. Trust me, with what I'm doing soon, a lot of people will be upset. I'll let you know soon what I'm talking about.
Old 05-18-2009, 01:41 AM
  #324
i think alot of guys thought they would slap on a tvs and some supporting mods then hit the rollers expecting 350... when they didnt make nearly that and barely broke 270 it broke down there confidence and with that the numbers went into the closet...
but, what i think they dont realize is a sc car takes a little more tuning and is a little finicky at times. its not a turbo car where you cram in a bunch of air and fuel and make great power, it just takes alot more than that...
on the same tune you might be making 320 one day and only 295 the next... that what suck to me about sc's their to picky...
turbo makes the same psi no matter what, (generally) and usually the same temp air or close to it. (cool dense air charge, and alot of it) but thats just my opinion
Last edited by hungryhip-ccp; 05-18-2009 at 01:51 AM. Reason: Automerged Doublepost
Old 05-18-2009, 01:43 AM
  #325
if there's one word i would use to describe this whole process, it would be patience.
Quick Reply: 400 wheel horsepower supercharged...
