42lb STage Question?
Old Aug 10, 2007 | 12:57 AM
Sanat's Avatar
Okay sorry If this may be a stupid question but I got to know.
GM Stage I kit is only 42lb Injectors that come flashed already(I think that's the proper terminology)
now.. If I buy 42lbers and get a tune with HPTuners.. will that equal out to almost the same thing??!
Old Aug 10, 2007 | 01:00 AM
DrPuttsSS/SC's Avatar
Yeah, they will tune for the injectors.
Old Aug 10, 2007 | 01:01 AM
chevysalesman614's Avatar
actually it's better. (better whp gains from custom tuning, except you dont have a warranty)
but you might as well just spend the extra $100 and get a new 2.9" pulley too since you're getting a dyno tune (probably 15-20whp over what you'd already have with the injectors and tune)
Old Aug 10, 2007 | 01:48 AM
Sanat's Avatar
so if I buy the GM belt 2.9pulley 42lb injectors and a good tune.. I will be set?
also.. with not belt slips etc?
Old Aug 10, 2007 | 10:40 AM
williamhvx1's Avatar
yes not slips i am runnig that setup like a lot ppl here jsut make sure the idc in the setup with hptunner is not high.... and get better spark plugs like nkg 7r or something like that and think about dual pass setup for you next big mod....
Old Aug 10, 2007 | 10:50 AM
Edubs's Avatar
NGK BKR7E, right on...
Old Aug 10, 2007 | 10:53 AM
Sanat's Avatar
ight.. cool. thanks for the help guys.. with that set up(2.9/42lbers) what kind of numbers is that produc'n?
I also have exhaust and airbox mod.
Old Aug 10, 2007 | 11:16 AM
well i belive a gm stage 2 is 240hp to the crank so is somthing like that for that setup.... a little better
0 to 60 in the mid 5 second and low 14 second the quater mile
Last edited by williamhvx1; Aug 10, 2007 at 11:16 AM. Reason: Automerged Doublepost
Old Aug 10, 2007 | 11:24 AM
Edubs's Avatar
Don't worry about hp numbers bro, worry about trap speeds. That's a better indicator of what your car is capable of. The nice thing about a custom tune is, you can play w/ the torque management to reduce power in 1st gear for traction and go all out in other gears. Every dyno is different, bhp wise, you're looking at around ~260 depending on how your other mods react to it. Could def be higher...
Old Aug 10, 2007 | 11:33 AM
Sanat's Avatar
ight that's cool thanks again guys!
Old Aug 10, 2007 | 11:40 AM
Edubs's Avatar
Good luck, and make sure you find a reputable tuner. I don't know where you are in the country, but go onto the regional forum and find people around you that have done the research already.
Old Aug 15, 2007 | 08:06 PM
NinjaHampster's Avatar
does anyone have a part number for the NGK bkr7e spark plugs by any chance?
Old Aug 16, 2007 | 08:46 AM
Edubs's Avatar
Ngk-6097
Old Aug 16, 2007 | 11:31 AM
Area47's Avatar
Rent me! per hour
Originally Posted by Edubs
Ngk-6097
the magical turbo honda plug.
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
