50lb injectors on 2.8" pulley
Old Dec 28, 2006 | 09:34 PM
Boost Fr33k's Avatar
so for xmas i got these 50lb injectors by PRECISION and 2.8 pulley.
never really heard of 50lb inj. but i guess theyre legit.
http://www.cobaltperformanceparts.co...roducts_id=215
any advice would be good
Old Dec 28, 2006 | 10:45 PM
CHARGDSS's Avatar
did u get the harness to hook those badboys up?
Old Dec 29, 2006 | 12:17 AM
Ljavy17's Avatar
Good luck tunning those 50 lbers. Youll need a lot of work for that. Or at least it wont be easy. since there is noone with 50lbers. all our tunes are based on 42 and 60 lbs.
Old Dec 29, 2006 | 06:06 PM
shiftingloco310's Avatar
just a question....doesnt the stage 2 reflash support up to 53# injectors? i thought i saw something like that around the forum. if that is the case would the computer compensate for the larger injectors?
Old Dec 29, 2006 | 07:17 PM
CobaltPerformanceParts's Avatar
If you need the injector clips let me know. I will ship them out to you free of charge since it was a xmas gift. The clips however your going to need to solder the ends to your harness. I know some of the other retailers have a full harness you can get.
Old Dec 29, 2006 | 07:19 PM
Witt's Avatar
Just change the IFR table to reflect the new injector flow rate.
Old Dec 29, 2006 | 07:25 PM
2006ArrivalBlueSS's Avatar
It has been discussed many times on this forum that 42# injectors with our stock fuel rail pressure act more like 50#'ers.
Old Dec 29, 2006 | 07:28 PM
Witt's Avatar
And the 50s are even higher. All injectors are rated at a standard fuel pressure. I wanna say 3 bar off the top of my head.
Old Dec 30, 2006 | 04:34 AM
yeah i know about the harness and all but like some of you said.. im just kinda cautious because most tunes are based on 42lb, 60lb etc.
Old Dec 30, 2006 | 08:56 AM
zinner's Avatar
Moderator Alumni
He should be fine with 50# injectors. There is a single map for the IFR that would really need to be changed. In the end 50's might be easier to tune because the stock IFR can handle the flow rate where the 60's are more difficult to tune.
Let us know how it goes.
Old Dec 30, 2006 | 10:11 AM
06blackg85ss's Avatar
thats what I was thinking
Old Dec 30, 2006 | 10:33 AM
zinner's Avatar
Moderator Alumni
Witt also touch on a good point. While our fuel pressure is higher we need to remember that the Manifold Pressure will balance out the fuel rail pressure. So it's 60 PSI in the fuel rail and probably ~15 PSI (or less depending on your pulley) in the manifold so it's a relative 45PSI.
DarrenGC
Dec 24, 2021 01:55 PM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
