574's engine & turbo build all in one
Old Jun 30, 2013 | 07:58 PM
  #151
c130aviator's Avatar
i am not trying to be a jerk but those look horrible! Did you cut those with a torch?
The machining on the block is to very tight clearance when you go to install those, if they are marred up they may not go in very cleanly, sit crooked, wear on the chain etc. Do those things spin freely with a little bit of oil in them? Have you tried to slide them into the block.
Look at the pics in post 126. I had mongorat make those up for me. I think he just used a cutoff wheel, they are harder to tighten the bolt after you take them apart but you can install them in the block and use a screwdriver or similar sized tool to hold against the cog then tighten them with red loctite.
Hope those workout , they just look rough.
Old Jun 30, 2013 | 09:38 PM
  #152
574's Avatar
574
I haven't tried to put them in yet. Cut them with a saws aw. Never done it before, I just cut and ground them down a bit. I was planning on cleaning them
Old Jun 30, 2013 | 11:16 PM
  #153
did you take them apart before cutting them? it makes it a lot easier.
Old Jun 30, 2013 | 11:41 PM
  #154
574's Avatar
574
Nope... Just cut them as short as I could
Old Jul 4, 2013 | 11:41 AM
  #155
574's Avatar
574
Piston rings are gapped. Waiting on new oil squirters and BS deletes from mongorat then assembly will start
Old Jul 4, 2013 | 11:47 AM
  #156
it goes pretty quick now that you have all the parts. GL
Old Jul 13, 2013 | 01:00 PM
  #157
574's Avatar
574
Used "the right stuff" sealant. In correct torquing order with new bolts I did, 15ft lbs then 70 degrees then 20 degrees
Oil squirters were torqued to 18ft lbs with a dot of red loctite
Outer griddle bolts (13mm) all torqued to 20 ft lbs
All bearing jornals were rubbed with lube, rear main seal was lubed and set in place.
I hope to have pistons and rods in tomorrow afternoon along with the head put on
Old Jul 13, 2013 | 01:12 PM
  #158
looks good man.
Old Jul 14, 2013 | 10:20 PM
  #159
574's Avatar
574
Another day in paradise. Seriously thought of pitching the project tonight.
Old Jul 14, 2013 | 10:53 PM
  #160
now what?
Old Jul 15, 2013 | 09:50 AM
  #161
noorj's Avatar
don't do that! your doin way too good man this thing is gonna be a beast, keep at it
Old Jul 15, 2013 | 10:14 AM
  #162
CudaJoe's Avatar
Looks nice, dont give up. You already have alot of time invested and its coming along nicely. As everyone else said, the rest should come together real nice
Old Jul 15, 2013 | 11:32 AM
  #163
574's Avatar
574
Found last night piston to walk clearance is slightly off. I think we got something figured out
Old Jul 15, 2013 | 11:50 AM
  #164
noorj's Avatar
does that mean the hone was done incorrectly?
Old Jul 15, 2013 | 12:00 PM
  #165
574's Avatar
574
Correct. My pistons were measured at the machine shop, so since my #3 cyl is the tightest we are going to just switch the 3 &4 pistons since cyl #4 piston measured the smallest.
Old Jul 15, 2013 | 12:08 PM
  #166
noorj's Avatar
Do you mind sharing the actual numbers? I'm just curious how far they should be. And does this mean that the rings are going to be off as well?
Old Jul 15, 2013 | 12:09 PM
  #167
mrbelvedere's Avatar
I bet it will still be to tight and if it is you will trash the pistons
Old Jul 15, 2013 | 02:21 PM
  #168
Tjolley's Avatar
He very well might trash the sleeve also.
Old Jul 15, 2013 | 05:55 PM
  #169
.004
Old Jul 15, 2013 | 06:25 PM
  #170
Tjolley's Avatar
.004 is the rule of thumb
The clearance will be more depending on boost pressure max hp. Bla bla bla.
Mine r .0045
Old Jul 15, 2013 | 07:48 PM
  #171
574's Avatar
574
Even on the tightest cyl #3, .004 fits
Old Jul 15, 2013 | 08:32 PM
  #172
Tjolley's Avatar
Hoe much do ur pistons very in size...mine r all with in .0001 of eachother
Old Jul 15, 2013 | 09:24 PM
  #173
Mine r .0045
.004 is not the rule of thumb each piston maker has their own specifications depending on what alloy the pistons are made from and usage
Old Jul 16, 2013 | 12:01 AM
  #174
rico's Avatar
Nice build
Old Jul 16, 2013 | 01:02 AM
  #175
574's Avatar
574
If you were about to head over to pornhub look no further, I have updates
Not finished by any means. Head and rods are torqued. Odds and ends need to be finished but its late.
GDS MF'ers
