#60 injector question
Old Jan 18, 2009 | 12:23 AM
NVMYCOBALTSS's Avatar
To me, a small pulley is in th 2.5-2.7 range and I agree, 60's are needed. For a daily driver that rarely see's anything over 4000 rpm, you SHOULD, and i mean SHOULD, be able to run 42's on a ring as low as 2.8 and not have any issues. Obviously if you beat on it all the time, it will break regardless of what combo you are running with. 2 of the 3 of my "idiot" friends were running 60's, both dyno tuned and data logged for a few weeks.
What size pulley?
Last edited by NVMYCOBALTSS; Jan 18, 2009 at 12:24 AM. Reason: Automerged Doublepost
Old Jan 18, 2009 | 12:30 AM
Zach06CobaltSC's Avatar
Is it possible to use 42lbers and a 2.8inch pulley? Yes.
Is it smart? No.
Should anyone recommend it? No.
How about on a daily driver? No!
It's just stupid to run your injectors static. Even on a daily driver, it's still stupid. Why would you want to do it? Why, its illogical to want to push you injectors to the breaking point.
Granted if you NEVER push you motor to higher rpm's it doesnt matter if you use 42lbers with a 2.5inch pulley. But if you are going to see higher rpm's you should do so knowing that your car can handle it.
Your friends must have either again had a bad tuner, or didn't have cooling mods. Cobalts that are tuned properly and have cooling mods will last. You call your friends the idiot, but yet you are doing the same thing to your car?
Why do you think your friends cars broke?
Last edited by Zach06CobaltSC; Jan 18, 2009 at 12:30 AM. Reason: Automerged Doublepost
Old Jan 18, 2009 | 12:31 AM
Where's the log, pulley size, rpm band, and TPS reading.....
Old Jan 18, 2009 | 12:32 AM
I will post it up when I find it. How about answering my question, why do you think your friends cars all broke?
Old Jan 18, 2009 | 12:42 AM
Back peddling is all I am seeing here....
Redefined1 - Don't listen to NVMYCOBALTSS as he obviously doesn't know what he is talking about. It's very possible that his friends blew up there cars as they are idiots, but I can tell you that it was not solely the pulleys fault.
Both were running CXR heat exchangers and meth, their issue is in bold above.
Old Jan 18, 2009 | 12:47 AM
Out of curiosity how did they "beat" on there cars. Constantly track them, autocross them, doing donuts, racing in reverse? What do you define as beating?
Old Jan 18, 2009 | 12:49 AM
Street racing on the weekends was the sole purpose of the two that blew up. Spend the week in the garage, come out on the weekend and hammered all weekend.
All the way to redline in most cases...
Last edited by NVMYCOBALTSS; Jan 18, 2009 at 12:49 AM. Reason: Automerged Doublepost
Old Jan 18, 2009 | 12:51 AM
Sucks for them. I know of a lot of cobalts that take massive amounts of abuse though and handle it quite well. If you build your car correctly and tune it right, take care and maintain it, it will last. Cars can handle the occasional abuse if built correctly. I consider occasional as once or twice a week, such as a "weekend warrior".
Redline is defined by the tuner so that doesn't tell us much. If they were taking it over 7500 rpm's often without a built valve train that would explain a lot.
Old Jan 18, 2009 | 01:14 AM
They were both set at 7200, Of the people with 60's and 2.6, one had piston issues, the other is believed to have been a head gasket.
I searched on HPT forums and found this nifty little line... Take it for what it is worth.
Originally Posted by hpt forums
for a street car running 100% IDC will not break anything, a street car runs about 99% of the time in part throttle
SO, back to my original statement, you can run 42's if you want to. I will revise my earlier statement to running them with the ring that you and your tuner are comfortable with.
I would still like to see the IDC logs when you get them up....
Old Jan 18, 2009 | 01:49 AM
lsjwannabe's Avatar
gm stage 2 untouched on the 3.06" ring.
Also try to remeber the rpm is not as important as the pressure each new ring is bringing, with that pressure comes the heat.
Old Jan 18, 2009 | 01:59 AM
  #36
Redefined1's Avatar
is that saying 115% IDC with a 3.06 pulley????
Old Jan 18, 2009 | 02:06 AM
  #37
lsjwannabe's Avatar
Yes, the gm tune is rather rich
Old Jan 18, 2009 | 02:09 AM
  #38
Redefined1's Avatar
thats well over its duty cycle, wouldnt that be lean? i dont know that much about this stuff. correct me if im wrong
Old Jan 18, 2009 | 02:11 AM
  #39
lsjwannabe's Avatar
Yes the car starts to lean out if the injectors can not keep up. It also starts to break up up top as it can not sustain the amount of advance anymore either. Hence the 6* of knock you see at at the top of the gear.
Old Jan 18, 2009 | 02:12 AM
  #40
Redefined1's Avatar
im really glad i just bought some #60ers lol
Old Jan 18, 2009 | 02:15 AM
  #41
lsjwannabe's Avatar
Just get a nice tune for them and you will be all set.
Old Jan 18, 2009 | 02:21 AM
  #42
Thanks for posting that up! I appreciate it .
Old Jan 18, 2009 | 02:23 AM
  #43
rico's Avatar
ah i cant wait to get my 2.8 with 60s stage 2 belt and probably the ott ecu tuned with my mods . included to that my h.e installed then later on the dual pass and meth
Old Jan 18, 2009 | 09:11 AM
  #44
So, question LSJ, Just to make sure that I am reading that right, the MAX RPM was 6984. MAX IDC was 115% on a stage 2 flash with the stage 2 hardware?
I am just trying to understand the mechanics behind the graph and the details associated with it.
Thanks for posting up the graph.
Old Jan 18, 2009 | 10:15 AM
  #45
lsjwannabe's Avatar
Yes 6894 rpms all stage 2, i believe this user had an intake as well. If you look at the log though you will see that by 6k rpms its already pver 100% duty cycle. After 80% you are along for the the ride.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
