60 #'s what kinda gain?
Old May 3, 2009 | 11:58 AM
pinoypapi198369's Avatar
I have a 2.85 pulley with stage 2, I am interested in going with 60 #'s and was curious as to what kind of gains you guys would guestimate. I haven't been able to get the results i was looking for through the search method I'm just posting my question, so don't bash me. I did try to search
Old May 3, 2009 | 12:12 PM
Mattman6's Avatar
none.........
Old May 3, 2009 | 12:39 PM
Snakes709's Avatar
all depends on the tune man, u might only gain 5whp or u could gain 30whp, depends on the tune.
Old May 3, 2009 | 12:43 PM
G85 SS's Avatar
Nothing unless you tune for them.
Old May 3, 2009 | 12:44 PM
chevysssc's Avatar
you will be able to run a richer safer tune
Old May 3, 2009 | 12:45 PM
drew1991sf's Avatar
if u dont tune for them ur fucked.....lol
but if u tune for em prolly 10-15whp
Old May 3, 2009 | 12:48 PM
elecblue06's Avatar
wtf... WTF .>>>WWWWWTTTFFFF... .. you don't gain any HP from injectors.. but you do gain the ability to tune for a smaller pulley the PULLEY gives you more hp ..
Old May 3, 2009 | 12:52 PM
damien's Avatar
Finally someone smart lol.
Old May 3, 2009 | 02:12 PM
Mattman6's Avatar
Whoever says you will gain any hp greater than like .5 is dumb. You will have no gains with 60s. People who say that might as well say yeah, lose about 10 pounds of body wieght and youll gain 7-10whp.
Old May 3, 2009 | 02:19 PM
daythecountrydied21's Avatar
says the man who didn't get any hp cause he can't tune.
Old May 3, 2009 | 04:31 PM
burnrubr88's Avatar
Says the man that cant remove his bumper, OR tune.
Old May 3, 2009 | 04:53 PM
damien's Avatar
Dick slap to the mouth.
Old May 3, 2009 | 05:49 PM
looks like i got mine off dandy sir.
Old May 3, 2009 | 07:58 PM
ralliartist's Avatar
:facepalm:
Old May 3, 2009 | 08:57 PM
Jrhdpaintball's Avatar
less likely of leaning out ur engine...idc's are going to be alot less with 60's..but 42lber idc's is another arguement
Old May 3, 2009 | 09:08 PM
G85 SS's Avatar
True, but still not netting any more power than what he currently has.
The only way he will see power is with a tune or like what elecblue06 said.
Old May 4, 2009 | 02:00 AM
leviticus88's Avatar
None!
The tune for the 60's might get more power but a tune on 42's might get more power too.
Old May 4, 2009 | 02:05 AM
Redefined1's Avatar
when u tune all you do is lean it out. you will gain absolutely no power. you can lean out 42`s just like you can lean out 60`s. you will lean them both out to the same air to fuel ratio resulting in the same numbers until you drop a pulley size and retune
Old May 4, 2009 | 03:04 AM
leaning it out and maxing idc's are totally differant... id much rather properly lean out 60's rather than 42's... ur looking at roughly 70% idc with 60's and im sure over 110% with 42's... power wise no differance... but when ur car is parked in ur driveway becuase u just blew ur engine... id think 200 bucks for 60lbs injectors seems pretty cheap...
but power wise no i dont see a differance if both have the right tune worked out
Old May 4, 2009 | 06:24 AM
Zach06CobaltSC's Avatar
Glad to see your learning jason .
Jason has a good point, your idc's are going to be very very high with 42lbers and they WILL be static. If you upgrade to 60lbers you don't have to worry about starving your motor of fuel. It's always in the tune, but 60lbers would be a wise choice if your going to stick with that pulley or even go lower.
Power wise however injectors do not ADD power, the smaller pulley and the tunes do as has been stated. However we all recommend you go with 60lbers so you don't run those 42lbers static.
Old May 4, 2009 | 09:04 AM
had to learn from someone
Old May 4, 2009 | 01:26 PM
Redefined1's Avatar
u think with a 2.8 pulley you will see 70% use of #6o injectors. deffinetely not. a 2.8 with #42`s will be high but that was not my point. my point is that it will not add power. how you make power is pulley size and leaning out your injectors to fit your pulley size.
Old May 4, 2009 | 01:56 PM
G85 SS's Avatar
Right. My IDC's are ~120% @6K rpm with a 2.9 and 42's. But that is on a GM tune file. If you get a custom tune your IDC's will drop a little because you can lean the car out a little. GM tune is rich. How much it will drop the IDC's I have no idea.
I think I am going to jump up to 60's but before I do, I'm gonna get my progressive meth kit installed and get a tune to see what my IDC's look like afterwards. They're still gonna be high but not 120% high. lol
Old May 4, 2009 | 01:58 PM
ShortStack's Avatar
Personally... i think it is better to just get the standard meth kit...
id rather have all my cooling at once.
Old May 4, 2009 | 02:01 PM
Jazer's Avatar
lol @ gaining HP just from injectors.
Injectors allow you to add more fuel to the car. That is it. For example, if you are running more boost, you will need more fuel to keep the right a/f mixture. So if you are running high injector duty cycle (IMO above 80/90%), that means it time to get a lil bigger injector, that can throw more fuel in there.
