60lb injector harness install question
The harness is scribed 1-4. I just want to double check that these numbers match up to the cylinders. And it's 1-4 start from the passenger side right? Thanks.
um....thats the way they work...now I am wondering
when you install them on the fuel rail, its upside down, you put the shorter set on the left and then flip it over and it ends up on the right....
I meant from the plug...
the longest from the plug should be to the left when installed...
with the plug to the right
So i did a continuity test on the wires in the harness, and compared it to the stock harness, according to the continuity test, if you are going to run the wires in the same orientation as the stock harness, 1, 4, 2, 3 is in fact correct.
