60lb injectors?
Old Dec 17, 2007 | 02:45 PM
supersix's Avatar
60lb injectors?
I am just wondering how you guys are putting 60lb injectors on your cars. I am tuning an 07 cobalt ss (using HP tuners) with 2.7 pully, cold air kit, and 60lb injectors. However, the flow rates values that I need to use max the injector table at -45Kpa.....How are you guys using 60lb/hr injectors? Also what power are you guys seeing out of similar setups?
Old Dec 17, 2007 | 03:46 PM
RedlineBrian's Avatar
1 million hp.
Old Dec 17, 2007 | 03:50 PM
06blackg85ss's Avatar
for injector tables send me your email in a pm and I'll send something for you to look at.
for power with a safe tune you should be @260whp with a more aggressive tune in the 270+whp range
Psykostevo's Avatar
You will see that the table maxes out around 65, and you will need to calculate way up into the 80's or more.
You are stuck there. make sure you get them set right down low, so that your idle and cruise are proper, and then you have to jimmy rig it under WOT.
Old Dec 17, 2007 | 04:19 PM
Area47's Avatar
Rent me! per hour
we use magic twinkies.
the table maxes at 63.5
the injectors flow more than this at 58 psi.
mathmatical magic must happen to maintain a constant. 260 is a good number to aim for, while keeping it alive for some time.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
