7000rpm limiter
Old Nov 25, 2006 | 12:19 PM
AdamRedSS's Avatar
7000rpm limiter
hey, i want to change the rev limiter to 7000, but am keeping my car stock only with an intake on it. can i just change the rev limiter without gettin the rest of the flash? where could i do this? hp tuners?
Old Nov 25, 2006 | 12:22 PM
D4u2s0t's Avatar
why are you upping your rev limiter if you're keeping your car otherwise stock?
you can do it with hp tuners
Old Nov 25, 2006 | 12:25 PM
StinkBOMB's Avatar
HP tuners can do it. Just find a tuner and tell him what you want.
Old Nov 25, 2006 | 12:26 PM
memphisr24's Avatar
HPTuners....But I think you would need to create tables past the 6500 rpm mark right since the stock tune wouldn't have tables past 6500 I would assume???
I haven't seen a stock tune yet so i'm just guessing.
Old Nov 25, 2006 | 12:35 PM
AdamRedSS's Avatar
how could i find a tuner in my area that would have the right stuff for my car?
well, i am only keepin it stock cuz i cant really afford to do what i want to it and i dont have time to go to the strip very often....MEDSCHOOL...
Old Nov 25, 2006 | 12:43 PM
D4u2s0t's Avatar
honestly, i would save the few hundred that it will probaly cost to raise the limiter, which is somewhat pointless on a stock car, and get an intake or an exhaust or something...
Old Nov 25, 2006 | 12:44 PM
memphisr24's Avatar
Make a new thread/post up in the regional section of the site and ask if anyone has HPTuners in FL. I belive a guy named Ljavy or smoething does tunes in FL.
Old Nov 25, 2006 | 12:47 PM
BravoPuma6's Avatar
u can do it, but you idc will be high. but you can do it. what part of florida u in?
Old Nov 25, 2006 | 12:49 PM
memphisr24's Avatar
You think thats high???? Try on my 7400 rpm rev limit for size
.............................................whats that noise?
Oh, just my valve springs floating lol
too bad I only get about 2-3 lbs of boost past 6500 rpm
Old Nov 25, 2006 | 12:50 PM
BLKblurr06's Avatar
not necessarily pointless, raising the limiter to 7k complimets the gear ratios more for better acceleration. If you can reach 7k in any gear that means you get to start at higher rpm in the next gear when you shift. Point is that even if you dont up the power any you can get better acceleration by doing this. I would definitely get an intake b4 raising the limiter, higher rpm is more airflow-demanding
Old Nov 25, 2006 | 12:52 PM
memphisr24's Avatar
Dude, just get GM stage 1. ALl that does is raise the rev limiter and give u injectors...
Old Nov 25, 2006 | 12:58 PM
martinsmu's Avatar
Yeah seriously, get a GMPP S1... and that keeps ure warranty, gives you the extra 500k and a few extra hp up high. I think the power with the gmpp S1 is the same, just the engine is continuing to make power till redline. So the car would feel the same, just the 500K extra with extra hp to match those revs
Old Nov 25, 2006 | 04:26 PM
Blown 4-banger's Avatar
If you raise your rev limiter to 7000 on stock injectors, have fun getting them up to 108% duty cycle.
Old Nov 26, 2006 | 01:02 AM
BLKblurr06's Avatar
500k? wow with a total of 506,500 revs you would have any crotch rocket for lunch! Is there an intake available to support such airflow demands? Just kidding, man.
Old Nov 26, 2006 | 01:11 AM
BLKblurr06's Avatar
500 more revs generating an additional 30 whp? dont think so, it should be quicker all the way through and not just in the extra 500 revs. if that were true, it would feel like vtec kicked in once you got past 6500rpm, sweet!
Old Nov 26, 2006 | 01:22 AM
memphisr24's Avatar
I think you will get 10 whp out of the GM Stage 1 kit....I belive it's peak power is ~6800 rpm's???
Old Nov 26, 2006 | 02:58 AM
Asphalt Assault's Avatar
Honestly I have 7000rpm and there is not power up there. I short shift my car to get my 1/4 mile results. the secret is out.
Old Nov 26, 2006 | 04:11 AM
Psh! Thats nothin, on my pump gas tune I shift at 5800-6000! There is NO power what so ever past 6000 rpm, I set it like that so I wouldn't be thrashing it up to 7000 rpm all the time. My race gas tune makes insane power up to about 6700-6800 then it just makes crazy power up to 7100
Old Nov 26, 2006 | 06:34 AM
thedubsack85's Avatar
i have the stage 2 kit. and it increases horse all over the rpm range. i push 13 pound of boost at 3k rpm. and a peak of 14.8 and havent tuned my car yet. have hp tuners and 60's
Old Nov 26, 2006 | 12:19 PM
What size pulley you running to need 60# injectors? I make 16 at 3000 and peak at 18.5 with a 2.6".
RaginChopsuey
Oct 27, 2015 01:27 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
z28addiction
Sep 28, 2015 12:03 AM
grampss
Sep 27, 2015 08:51 PM
