76 mm pulley safe??
76 mm pulley safe??
I have an 06 ss/sc with GM stage 2, and an AEM cold air intake. Will I be safe if I run a 76mm pulley (GM Stage 3) on my stock exhaust set-up or should I get an exhaust system and then install the smaller pulley? I will be getting a header, downpipe, and cat-back in about 3 weeks, but I do not want to install my pulley now if it is going to cause me any potential harm.
1.9 MM = 0.0748".
But you are right about it not causing problems...it might not even cause more boost.
pretty much how much your injectors are being pushed and worked. supposedly your not supposed to go over 88% and running a 2.8 will put it at 90 something, but in my opinion it depends on your location and altitude. i run a 2.8 and my idc is just fine with 42. lbers. plus if you dynotune your car you will be able to see it on your graph and the print outs. this has been a very touch issue, do a search on it read up on it and make your own conclusion from what you read and what you know.
He mentioned IDC's which had nothing whatsoever to do with this particular thread.
go ahead and not worry.when you run a 79mm pulley even if u have the stage 2. running a 2.8 pulley will max out your injectors.. i live in cali at 1,400 foot elevation. and if i were to run a 2.8 my IDC would be at 110%.. which isnt good.
HPTuners smoothes things out. You'd be surprised how the IDC's come down. That being said I would not use a 2.7" on 42.5#er's.
patooyee
Oct 1, 2015 01:07 PM
