8000 Rpm???
Old May 24, 2008 | 12:07 AM
hungryhip-ccp's Avatar
8000 Rpm???
who here is running the lsj up to 8k rpm? what is needed to do this?
1. valve springs and retainers...
2. neutral balance shafts...
anything else? i really think this would help with 1/4 mile times, and i am wondering why more people arnt doing it?
Old May 24, 2008 | 12:11 AM
Raven SS's Avatar
yes thats what u need...and its not as easy as it "seems" thats why people dont do it
2K5SS/SC?'s Avatar
Cams that will allow power up to the 8000rpm range as well would be good to add to that list as well as some adjustable cam gears.
Talk to Witt and Area47 about this since they have a lot of experience and hands on with it.
Old May 24, 2008 | 12:17 AM
most dyno graphs i have seen, including mine make power all the way to red line... so would cams be needed or recommended?
for my next couple of mods im thinking about getting
1. forged 10.5:1 pistons
2. valve springs and retainers
3. neutral balance shafts
4. head gasket and studs
5. mild head work
Last edited by hungryhip-ccp; May 24, 2008 at 12:17 AM. Reason: Automerged Doublepost
Old May 24, 2008 | 12:27 AM
lsjwannabe's Avatar
don't run the high of compression your running a boosted engine.
Old May 24, 2008 | 12:31 AM
huh? i plan on having all cooling mods plus meth... what 10:1... i wanna make the most hp possible on the sc looking to make 275+75 shot = turbo lsj territory
Old May 24, 2008 | 12:34 AM
lsjwannabe's Avatar
10.1 is the limit i would go i think 9.5 is perfectly fine to be honest. a full point in compression is about a 4% power gain at the cost of having to run that high octane and lower timing.
Old May 24, 2008 | 12:39 AM
9.5:1 is stock right? i wanna go at least 10:1... i shouldent have to pull too much timing, cuz of meth, right?
Old May 24, 2008 | 12:47 AM
Raven SS's Avatar
im running 10:1 and have to pull hella timing and im fully ported (which should lower compression)...listen to the man lol
Old May 24, 2008 | 12:50 AM
lsjwannabe's Avatar
wsfrasier was running 20* i think on meth, high compression is not needed on a boosted engine becuase of the compressor (s/c or turbo) forcing the air down into it. It does a good job filling that cc all by itself.
Old May 24, 2008 | 12:56 AM
ok thanks, i'll probably stick with 9.5:1 then... **** well i might be able to squeeze off a 75 shot on stock internals then... i know some are doing it. it just thats by far in no way a safe build!
Old May 24, 2008 | 01:04 AM
InfinityzeN's Avatar
You'll need more fuel then what those 42.5#s put out to run to 8k also.
Old May 27, 2008 | 05:27 PM
ggarcia86's Avatar
i'm searching, and havnt found what company sells valve springs for the lsj that can handle 8k or so?
Old May 27, 2008 | 05:30 PM
ralliartist's Avatar
you really need to search harder then. Supertech and ferrea make valve springs for our cars.
Old May 27, 2008 | 05:37 PM
ggarcia86's Avatar
i got some more info, but i want to keep the stock cam, does anyone know the rpm limit on the jbp springs that are supposed to be perfect stock replacement hight?
Old May 27, 2008 | 05:42 PM
an0malous's Avatar
show me a dyno where its makin power to redline?
cuz every one ive seen it starts to drop at about 6800
Old May 27, 2008 | 05:44 PM
sleepercobaltsc's Avatar
http://www.allecotec.com/product_inf...roducts_id=119 what about those?
Old May 27, 2008 | 06:30 PM
Blown 4-banger's Avatar
You are going to need a built motor, because there is no point in reving to 8000 rpm without cams and head work. The stock head has tiny exhaust ports which severely choke the motor above 7000 rpm. If you port the head, and get some decent cams, then your making more power than the stock internals can safely handle.
Old May 27, 2008 | 07:01 PM
yeah like mine in my sig lol..... i know i meant, its still making good power like for example my peak hp was 240.6 at 6758 rpm or something but at 7136 rpm i was still making 239.3 and then it shows i hit rev limter... WTF... but its set to 7300 so i dont know what was up with their tach pickup so im thinking 72-7300 rpm still making 239 that only 1 hp less...
i dont know tell what you think about this... ^ and this was all before port and polish throttle body, blower, catless dp and meth... all i had then was I, H, 2.8 and ZZP tune... so know with it breathing better and flowing good for top end hp i want like 7800 rpm for track use...
Old May 27, 2008 | 07:47 PM
an0malous's Avatar
I could be wrong on this.....
but im pretty sure your cam is still going to be the deciding factor in where your power begins to drop off, regardless of porting/exhaust/meth....
Old May 28, 2008 | 04:26 AM
true... i think your right about that one...
Old May 28, 2008 | 10:12 AM
lsjwannabe's Avatar
i made peak power at 7200 with no timing in the car
Old May 28, 2008 | 12:18 PM
an0malous's Avatar
do you have a dyno sheet of it lsj?
i have yet to see one make higher power after 6800 with stock internals
Old May 28, 2008 | 12:21 PM
lsjwannabe's Avatar
yeah give me a sec
Last edited by lsjwannabe; May 28, 2008 at 12:21 PM. Reason: Automerged Doublepost
Old May 28, 2008 | 12:23 PM
06blackg85ss's Avatar
well on the higher boosted/hp cars stock cams, peak power is at 6200rpm. Need a decently bigger cam, and the supertech 76lb springs would be fine. Add in some nice forged slugs at 9.5:1 compression, nuetral balance shafts, and you're good to go.
Stay away from 10.1:1 and > compression, unless you run 100+ octane everyday,
