In theory you will be fine even in wot. Your maf should see the air changes and make the adjustments for you. I went from a 2.8 to a 2.7 with no changes at first. Im always logging/tuning my car when I have some time for it though. The only thing is you might hit some cells farther down your maf table. This is my experience and I tune my car.
If this pushes your IDC's past whatever threshold you deem 'safe' it might be cause for concern for you.
Don't go into boost and you should be fine.
yeah, but we're only talking about a tenth of an inch. I rolled with a 2.8, and then a 2.7 (both with an aftermarket h/e). So heat wasn't an issue. And as far as fine tuning goes, I would think our cars aren't going to run any more efficient with a tune for a 2.7 pulley and a 2.8 pulley. Not saying you're wrong, but we're not talking about a drastic change like converting to e-85 or turbocharging.
I'd imagine if you had 60's, you wouldn't be pushing your IDC until you run something smaller than 2.5
Just puttin it out there.
No argument intended.
Just information, in case anyone ever asks...
I logged 126% max duty cycle on 42lb injectors in combination with a 2.8 pulley and a stage 2 tune (no boost limiting) on someone's cobalt.
y do idiots go with 42z and a 2.8. 60z are a little more lol my duty cycle with 60z wot at 19 lbs 2.6 pulley r 79% when warm and 84%_ when cold lol I'm also pushing a total of 20 in both timing maps and when pe kicks in at 10lbs I get a extra 6 at 19lbs and when iat2z reach 135 I take timing out and have a afr at wot starting at 12.5ish to 11.3 at top end and I have no kr. I've tuned people running 2.8s and 42z and limited there boost till they got the 60z becuz I told them they were stupid lol. The most duty cycle I seen was also in the 130 range but this was when it was cold and car made 16lbs .......
But going from a 2.8 to a 2.7 won't hurt junk..... The PCM will command a afr of 14.7 when cruising until u go into pe table unless all u use is the ve and or the maf only. Your ltft will be off and so will your stft but your car will compensate 1lbs of boost... There will be tuners that argue. But it won't hurt, tuning the 2.7 is prob the better idea because your air coming in will be quicker but the tune u have now won't be far off for the 2.7
