about to buy 2.79 pulley and colder plugs...need reassurance
Old Aug 20, 2007 | 11:24 PM
Coblt ss super's Avatar
Originally Posted by jgarciarivera
Oh, there you are. What does it fit to?
it fits nates pulley, and its brand new
Old Aug 20, 2007 | 11:27 PM
lsjwannabe's Avatar
i thought he was talking about the hub
Old Aug 20, 2007 | 11:30 PM
DSMissed's Avatar
Just paid for the 2.9 from ZZP and the NGK's from Cobalt-Addiction.
Now one last question: how necessary is the dual pass intercooler plate?
Old Aug 20, 2007 | 11:31 PM
lsjwannabe's Avatar
please get it, i run my 2.5 pullied car and it is a life saver for cooldown
Old Aug 20, 2007 | 11:32 PM
ahh, for a 2.9 u probabaly dont need it, but its worth it, if so get the option B kit from CED, and there your set, i just actually started to put my dual pass kit together, made brackets, for the second surge tank and everything
Old Aug 20, 2007 | 11:34 PM
lsjwannabe's Avatar
why do you think it somes in stg3 you will want it trust me but wait until you can get a extra h/e to if you don't already have one
Old Aug 20, 2007 | 11:41 PM
DSMissed's Avatar
No I don't have a heat exchanger. So I should get a heat exchanger, then the dual pass plate? Or the other way around? How hard are each of them to install?
And so if I'm understanding right, the dual pass only helps in cool down?
Will it hurt my car if I don't have it at first? Cause it'll be a few weeks before I can get it.
Old Aug 20, 2007 | 11:42 PM
lsjwannabe's Avatar
no it helps to prevent heat soak better recliam the power you already have. get both of them at once so you don't have to redo the plumbing twice
Old Aug 20, 2007 | 11:48 PM
pinoypapi198369's Avatar
i'm running a 2.85 pulley with stage 2 and so have many others, haven't had any problems and gives me roughly 16-17psi
Old Aug 20, 2007 | 11:49 PM
lsjwannabe's Avatar
its only a matter of time trust me, unless yo drive normal and not like a retard
Old Aug 21, 2007 | 12:07 AM
  #36
DSMissed's Avatar
Ya, I ran my old GSX at 23 psi with no problems...for about 3 months til it detonated.
Old Aug 21, 2007 | 12:08 AM
  #37
lsjwannabe's Avatar
haha i like that
Old Aug 21, 2007 | 03:29 AM
  #38
SSdan's Avatar
Been doing the 2.8 pulley thing for months now. Definately runs lean up top, shifting at 6k RPM. Just need a tune.
Old Aug 21, 2007 | 05:44 AM
  #39
syP's Avatar
syP
2.8 feels the same as the 2.90..... which is probably a bad thing...
going back to the 2.90"
2.80" for sale.. anyone interested??
Old Aug 21, 2007 | 08:09 AM
  #40
splitimage's Avatar
Originally Posted by Coblt ss super
bye bye motor, with that 2.79, id say go 2.9 instead of a 2.79
what on earth are you smoking? byebye motor HAHAHAHAHA....
it honestly depends on your climate and elevation, some cars in certain areas can handle it fine, some are near sealevel and push more boost subsequently which takes the injectors out of there efficiency range.
i know plenty of guys who ran the 2.8 on the stg 2 for months without issues, its a rich tune as it is...leame that **** out!
Old Aug 21, 2007 | 10:26 AM
  #41
lsjwannabe's Avatar
it depends on how you beat on your car to
Old Aug 21, 2007 | 12:26 PM
  #42
Area47's Avatar
Rent me! per hour
anything below a 2.9/42.5's is bad.
i have logs to prove this.
Old Aug 21, 2007 | 12:28 PM
  #43
lsjwannabe's Avatar
no you don't stg2 and 2.8 works fine i know becuase i have driven it for 19 months and not a poblem but some pinging in the engine. * sarcasm*
Old Aug 21, 2007 | 12:32 PM
  #44
Area47's Avatar
Rent me! per hour
lol
i see what you did there
of course. im one of those crazy bastards doing this. with a built in saftey cushion
Old Aug 21, 2007 | 12:33 PM
  #45
lsjwannabe's Avatar
hahaha
Old Aug 21, 2007 | 04:01 PM
  #46
LUCKY333's Avatar
Too bad that you offer advice on something you know nothing about other than whats been told to you! I have run a 2.79 on a gm stage2 tune for almost 10,000 miles! Not so much as a code! And there are no IDC problems either! Believe me I drive hard every time I touch the key! And yes I have had it checked after the initial install and 1500 miles.
No disrespect but should you choose to comment in the future, use research, NOT hearsay.
GREAT POST DUDE! Thank you! Man o man, people spread stupidity on this site like its an STD! Finally someone that makes an educated post!
Old Aug 21, 2007 | 04:36 PM
  #47
Area47's Avatar
Rent me! per hour
i have a log file to discredit. this will be posted tonight.
in the mean time. go check your a/f from 2-7k with a wideband. i bet your injectors are pissed off, and the a.f is spiking at 6k to the 12's
Old Aug 21, 2007 | 04:43 PM
  #48
sscobaltscZ06's Avatar
Oh hell yes....our af is spiking high 12's from 4-6.5K wot with a 2.85, stage 2 and 42's and idc's at 117% at 6300 plus with the 2.85 and crap 91 octane its pulling 8-10 degrees timing wot. Just depends on alittude, temps and what not how itsd gonna do. Incidently I gotta wipe the black soot out/off of the tailpipe every 3 days. Go figure. Probaly gonna throw a 2.9 on until a tune is done or maybe even the S2 pulley back on, especially with cooler weather coming.
Old Aug 21, 2007 | 05:01 PM
  #49
Area47's Avatar
Rent me! per hour
if it makes you feel any better, i got 242 to the tire out of a s2 car in 100+ degree heat and 80% humidity.
heat plays a big role. when winter time comes, things get cooler. power starts to rise, and motors start to blow.
Old Aug 21, 2007 | 05:12 PM
  #50
I just ordered a 2.9 pulley this morning and taking the 2.85 off. Im just not comfortable running the 2.85 at sea level without a tune as the car is driven very hard and almost every gear in town shifted at 5k+. Might not make a whole lot of difference number wise but the idc's should drop down and afr's get somewhat better.
