about to buy 2.79 pulley and colder plugs...need reassurance
i was talking the pulley itself. you can get over 260 fwhp out of the stage 2 pulley, WITH other mods.
OK after reading this thread, I too have decided to go with the 2.9. I have the intake and working ok getting an exhaust. Living in northeast AL it is hot as hell here, but with winter coming I feel the 2.9 will still be safe. Car is running 12.5psi on stage2 now what will the 2.9 pulley bring the boost up to? anyone?
with stage 2 it should be around 15psi i believe. 12.5 is stock.
Ok so stage 3 pulley is ~2.99" and stage 2 is ~3.07" and going that extra .09 from 2.99 to 2.9 is really that much of a difference to make it unreliable?
2.79
its fine to run with a 2.79 pulley.
i have a 2.79 pulley 42 lb injectors GM stage tune cold air intake and have a 10.5 dyno tested a/f
SS33 has an almost identical setup to mine and a interceptor guage and he sees no knock.
I have had this discussion a million times on this site before. they always end the same.
i already know the posts that are coming after mine.
1.) HP tuners says idc is 128% duty cycle.
my rebutal the cars that i have seen blow engines around here were 60 lb cars running 2.5's and such.... i have yet to see somebody with my setup blow up their engine.
that being said...i am on the ragged edge of danger. i put down 253 hp 232 trq about 4 months ago at VT engines in lansing and had a 10.5 a/f we heard no knock or ping.
i do add octane boost before trips to the drag strip.
i have been running this setup for around 12,000 miles, two trips to the track, and multiple trips to the dyno.
all with 0 problems. i do throw a maf lean code once in a while but it turns itself off.
FYI, your local auto parts store should be able to get you the NGK BKRE7s for something like $1.29-$1.59 each... I just bought a whole box for less than a set from anywhere online.
2.8" w/ a stage 2 tune...
I also have the zex 1 step colder plugs and swear by them!
However, as of late I have been feeling a bit of hesitation above ~6200 rpms that I never felt before.
-Rich
-Rich
What kind of plugs does everyone think is the best copper iridium platnum? I have ngk 1 step colder iridium right now but i have heard you get better performance with copper? This is with the set up in my sig.
if they are so way off why have them in the car in the first place. i just ran my car to mins ago and watched my a/f it was at 11.6-1 my intake air temp was 145 max. im not at all worried about my engine blowing up. i have had several other tecks at my dealership look at my numbers and they all say there more then fine.
Right. So when I dyno'd my car and the A/F skyrocketed at roughly 6200, its not leaning out? Before I let off, A/F was high 12's....
yepo
