about to buy 2.79 pulley and colder plugs...need reassurance
Old Aug 22, 2007 | 07:29 PM
  #76
Area47's Avatar
Rent me! per hour
Originally Posted by IR0NS1N
So stick with just the stage 2 then?
a 2.9 isn't going to hurt the car. it puts in on edge. or if you want to stay safe, go to a stage 3
Old Aug 22, 2007 | 07:37 PM
  #77
IR0NS1N's Avatar
You have to have a stage 2 in order to do stage 3 correct? Also Ive never seen a place to buy a "stage 3" nor do I know what it entitles?
err did a search and found it! thanks!
Old Aug 22, 2007 | 07:53 PM
  #78
Area47's Avatar
Rent me! per hour
i was talking the pulley itself. you can get over 260 fwhp out of the stage 2 pulley, WITH other mods.
Old Aug 22, 2007 | 07:57 PM
  #79
06SS/SC STAGE2's Avatar
OK after reading this thread, I too have decided to go with the 2.9. I have the intake and working ok getting an exhaust. Living in northeast AL it is hot as hell here, but with winter coming I feel the 2.9 will still be safe. Car is running 12.5psi on stage2 now what will the 2.9 pulley bring the boost up to? anyone?
Old Aug 22, 2007 | 08:08 PM
  #80
IR0NS1N's Avatar
with stage 2 it should be around 15psi i believe. 12.5 is stock.
Ok so stage 3 pulley is ~2.99" and stage 2 is ~3.07" and going that extra .09 from 2.99 to 2.9 is really that much of a difference to make it unreliable?
Old Aug 22, 2007 | 10:24 PM
  #81
SSpartan's Avatar
2.79
its fine to run with a 2.79 pulley.
i have a 2.79 pulley 42 lb injectors GM stage tune cold air intake and have a 10.5 dyno tested a/f
SS33 has an almost identical setup to mine and a interceptor guage and he sees no knock.
I have had this discussion a million times on this site before. they always end the same.
i already know the posts that are coming after mine.
1.) HP tuners says idc is 128% duty cycle.
my rebutal the cars that i have seen blow engines around here were 60 lb cars running 2.5's and such.... i have yet to see somebody with my setup blow up their engine.
that being said...i am on the ragged edge of danger. i put down 253 hp 232 trq about 4 months ago at VT engines in lansing and had a 10.5 a/f we heard no knock or ping.
i do add octane boost before trips to the drag strip.
i have been running this setup for around 12,000 miles, two trips to the track, and multiple trips to the dyno.
all with 0 problems. i do throw a maf lean code once in a while but it turns itself off.
Old Aug 22, 2007 | 10:26 PM
  #82
burntorange's Avatar
I just run 93 octane always, never any booster, and have never thrown a code.....weird how different the cars are....
Old Aug 22, 2007 | 10:28 PM
  #83
SSpartan's Avatar
plugs
oh yeah i have 1 stage colder plugs from CA.
Old Aug 22, 2007 | 10:47 PM
  #84
yep, same here....good ole NGK baby
Old Aug 22, 2007 | 10:57 PM
  #85
Blur.fx's Avatar
Pave It All...
FYI, your local auto parts store should be able to get you the NGK BKRE7s for something like $1.29-$1.59 each... I just bought a whole box for less than a set from anywhere online.
Old Aug 22, 2007 | 11:00 PM
  #86
correct, I work part time at pep boys and picked up the iridium ones
Old Aug 23, 2007 | 12:02 AM
  #87
astrocrep's Avatar
2.8" w/ a stage 2 tune...
I also have the zex 1 step colder plugs and swear by them!
However, as of late I have been feeling a bit of hesitation above ~6200 rpms that I never felt before.
-Rich
Old Aug 23, 2007 | 10:08 AM
  #88
BlueSSupercharged's Avatar
What kind of plugs does everyone think is the best copper iridium platnum? I have ngk 1 step colder iridium right now but i have heard you get better performance with copper? This is with the set up in my sig.
Old Aug 23, 2007 | 11:07 AM
  #89
LUCKY333's Avatar
Originally Posted by BlueSSupercharged
if they are so way off why have them in the car in the first place. i just ran my car to mins ago and watched my a/f it was at 11.6-1 my intake air temp was 145 max. im not at all worried about my engine blowing up. i have had several other tecks at my dealership look at my numbers and they all say there more then fine.
Obviously two diffrent OPINIONS, I agree with blue SS. I can spout off all kinds of #s pertaing to IDCs, A/f, etc. All I can say is I am running and have been running a 2.79 pretty much since I got my car home from the dealer with the stage 2. My car is FINE! And I will log on in a year and tell you how its running because, I am not changing it. I have a buddy that owns beyond redline and does dyno tuning all over the state! I know that the injectors are 100% fine!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 24, 2007 | 12:31 PM
  #90
FNFAST's Avatar
GM stage 3 runs 50 shot of dry nitrous to 7000 RPMS with a 2.99 pulley and 42 lb injectors.
.2 inches is not going to lean the car out more than a 50 shot of nitrous.
This debate is weak.
Old Aug 24, 2007 | 12:38 PM
  #91
SSdan's Avatar
Right. So when I dyno'd my car and the A/F skyrocketed at roughly 6200, its not leaning out? Before I let off, A/F was high 12's....
Old Aug 24, 2007 | 12:44 PM
  #92
but when you spary the 50 you are also on a stage 3 tune and not the stage 2 tune correct? Aren't they different? just asking, not talking **** or trying to show up, just trying to learn....
Old Aug 24, 2007 | 12:46 PM
  #93
Area47's Avatar
Rent me! per hour
widebands don't lie.
yepo
Old Aug 24, 2007 | 12:49 PM
  #94
SSdan's Avatar
Wouldn't doubt them being different. I'm sure GM calibrated it some way that when it fires the nitrous it also dumps more fuel.
Old Aug 24, 2007 | 12:50 PM
  #95
and definately has much better timing for the added boost/ possibly nitrous
Old Aug 24, 2007 | 12:51 PM
  #96
SSdan's Avatar
I think they did their homework with the Stage 3 PCM. Especially the nitrous part.
Old Aug 24, 2007 | 12:52 PM
  #97
Area47's Avatar
Rent me! per hour
since we can't look at the calibration on the stg3 stuff. we are all left in the dark
Old Aug 24, 2007 | 01:29 PM
  #98
can you if you hook hptuners up to it? right?
Old Aug 24, 2007 | 01:32 PM
  #99
-Jayson-'s Avatar
nope different OS
Old Aug 24, 2007 | 01:38 PM
  #100
Area47's Avatar
Rent me! per hour
you can log them, but to actually download the map and look at it? nope. no can do
