? about cams
Your only choice is ZZP. or finding a set of the rare GM Racing cams like I have for sale.
There is always the option of custom, but that is a lengthy and expensive process, and they will most likely screw up the hex key in the exhaust cam for the CPS.
with the gmr cams the head will have to be setup for solid lash adjusters over on the r e d l i n e forums a guy has the stage 1 cams from zzp no meth and on pump gas with a 2,8 pully and is making a touch over 280 whp
The Comp intake cam has the following specs: 0.441 inch net lift with 218 degree valve duration at 0.050 inch lift on 109 degree lobe separation.
The Comp exhaust cam specs are 0.437-inch net lift with 220-degree valve duration at 0.050-inch lift on 109-degree lobe separation.
Just wanted to give a correction for the GM Racing LSJ Camshaft Specs.
no it side they fit the LSJ but some with the cam sensor was different ? idk still not sure if i wont to get cams now from all the debate in here bout what i do with the car, but if i do get cams they'll prob be ZZP's
They are just blank shafts, free spinning as opposed to the stock ones that are cut a certain shape to create vibrations that counter-act the rotating assemblies vibrations. Hence the name Neutral. You really only want to remove the stock stuff if you plan on spinning the motor to 8k. I wouldn't change them just for horsepower, isn't worth it.
I have a set of NBS that are getting installed next winter along with my head build. I am only installing them since the timing chain will be off anyways. Otherwise I wouldnt reccomend it just to do it. I belive the average gain on them though is around 5-10hp if I remember correctly since its less drag on the motor. Same concept as light weight pulley set, less rotational mass the motor has to turn to operate
