? about cams
Old Apr 13, 2011 | 01:40 PM
countrySS's Avatar
Your right absolutely, I know nothing. Which cams again were selling like crazy?none? Jc went 12s on stock cams. I believe 12.4
why don't we get back to the reason for this thread
Old Apr 13, 2011 | 01:43 PM
RooTBeeR's Avatar
Originally Posted by Area47
for road racing and a broad powerband. stock cams.
for drag and dyno numbers. aftermarket cams
so what are your plans for the car?
WSFrazier's Avatar
Your only choice is ZZP. or finding a set of the rare GM Racing cams like I have for sale.
There is always the option of custom, but that is a lengthy and expensive process, and they will most likely screw up the hex key in the exhaust cam for the CPS.
Old Apr 13, 2011 | 01:44 PM
Few people have gmr cams for sale in for sale threads lately
Old Apr 13, 2011 | 01:45 PM
countrySS's Avatar
dyno numbers and power street car with light drag racing
Old Apr 13, 2011 | 01:48 PM
RooTBeeR's Avatar
by street car you mean you still want it to be a nice DD car, or you mean like WOT on a hwy on ramp/roll racing street car?
Old Apr 13, 2011 | 01:53 PM
countrySS's Avatar
this it's not so much a DD but if my truck brakes down then i need the balt to get around
Old Apr 13, 2011 | 01:59 PM
mrbelvedere's Avatar
with the gmr cams the head will have to be setup for solid lash adjusters over on the r e d l i n e forums a guy has the stage 1 cams from zzp no meth and on pump gas with a 2,8 pully and is making a touch over 280 whp
Old Apr 13, 2011 | 02:00 PM
WSFrazier's Avatar
You might as well go aggressive then, ZZP Stage 3 or GMR.
Old Apr 13, 2011 | 03:26 PM
countrySS's Avatar
i'm thinkin stage 2
Old Apr 14, 2011 | 09:34 AM
  #36
WSFrazier's Avatar
nevermind here they are
• Duration @ 0.050" lift is 247° on the intake and 249° on the exhaust
• Maximum lift is 0.499" for the intake and 0.499" on the exhaust
• Lobe centerline is 116°
Not sure where you got those specs from, but the GMR cams are same ones in the LSJ build book, which says the follow:
The Comp intake cam has the following specs: 0.441 inch net lift with 218 degree valve duration at 0.050 inch lift on 109 degree lobe separation.
The Comp exhaust cam specs are 0.437-inch net lift with 220-degree valve duration at 0.050-inch lift on 109-degree lobe separation.
Just wanted to give a correction for the GM Racing LSJ Camshaft Specs.
Old Apr 14, 2011 | 10:48 AM
  #37
countrySS's Avatar
ok i got those spec. off of create engine depo on the cams they offer thought they were the same ones
Old Apr 14, 2011 | 10:49 AM
  #38
WSFrazier's Avatar
I think those are the "off the shelf" 2.2 Ecotec cams.
Old Apr 14, 2011 | 10:50 AM
  #39
countrySS's Avatar
no it side they fit the LSJ but some with the cam sensor was different ? idk still not sure if i wont to get cams now from all the debate in here bout what i do with the car, but if i do get cams they'll prob be ZZP's
Old Apr 14, 2011 | 03:56 PM
  #40
countrySS's Avatar
so how bout balance shaft delete kits any one messed with these and what are power gains, pros/cons
Old Apr 14, 2011 | 04:05 PM
  #41
just do nb shafts you can get the delete kit from gm anymore it has a shorter drive chain in the kit for the water pump
Old Apr 14, 2011 | 04:09 PM
  #42
countrySS's Avatar
but wouldn't the delete kit free up horse power
Old Apr 14, 2011 | 04:16 PM
  #43
so will the nb shafts and reread above the kit is no longer available
Old Apr 14, 2011 | 04:18 PM
  #44
countrySS's Avatar
so are the nb's lighter than stock or something
Old Apr 14, 2011 | 04:24 PM
  #45
WSFrazier's Avatar
They are just blank shafts, free spinning as opposed to the stock ones that are cut a certain shape to create vibrations that counter-act the rotating assemblies vibrations. Hence the name Neutral. You really only want to remove the stock stuff if you plan on spinning the motor to 8k. I wouldn't change them just for horsepower, isn't worth it.
Old Apr 14, 2011 | 04:51 PM
  #46
I have a set of NBS that are getting installed next winter along with my head build. I am only installing them since the timing chain will be off anyways. Otherwise I wouldnt reccomend it just to do it. I belive the average gain on them though is around 5-10hp if I remember correctly since its less drag on the motor. Same concept as light weight pulley set, less rotational mass the motor has to turn to operate
Old Apr 14, 2011 | 07:32 PM
  #47
kxrida2000's Avatar
level zero sells a balance shaft delete kit...i have it in my motor and it revs really quick.
Old Apr 14, 2011 | 10:03 PM
  #48
did your kit come with the shorter chain
Old Apr 14, 2011 | 10:33 PM
  #49
kxrida2000's Avatar
no u put in littloe sleeves inside the block and then there are bushing things that comes with the kit that the stock sprockets for the balance shafts bolt too
Old Apr 15, 2011 | 08:46 AM
  #50
countrySS's Avatar
yea this is the kit i was looking at and i knew it had to free up HP cause less drag
