Advice?
Okay Im deployed right now and Ive been buying parts for my cobalt so far ive got a 2.6 pulley, 60lb injectors, 2.5 DC exhaust, Injen coldair Intake, stage 3 ecu, Injector harness, S2 heatexchanger, and a twm shorthrow shifter. My question is what else should I get Im gonna have around 3,000 to play with before I get home on leave In april what else do I need to make all this work besides a tune my goal is at or above 300hp to the wheels Ive done a fair bit of research on the fourm but havent found anything fairly conclusive.
u should probably invest some of that cash... ur gunna throw ur stuff on ur car and still go HOLY ****! cus its a hell of a jump over stock. then the money u invested now will be worth more when u get bored of the performance of ur car and ull be able to afford more parts!. or just blow it on more cooling....
Get meth...with that 2.6, the heat exhchanger isnt going to be enough to cool the IAT2. Sure you can run it but you will heat soak bad and loose power. You got 3k to spend...hmm get the following (price for these parts are give or take estimate)
Devils Own Meth - $400
Header - $200
Downpipe $200
Custom Tune $300? Not sure on tuning prices, i got mine for free and then another guy tuned my tvs for a few hundred.
OTTP Stage 2 Tranny Mounts - $400
If you are going to race, Stage 2 axles are a good thing to have
Header - $200
Downpipe $200
Small changes such as a 2.8 to a 2.7 a tune will help abit but not required
Personally i say go with 2.8...but thats a bias opinion because its what i did and never tried anything else. Also im not sure what size u r running now but if u drop pulleys u will either need a bigger tensioner or a smaller belt.
yea its bone stock right now I have a smaller belt what mods would I need in order to run the 2.6 Ive got the large heat exchanger would I need the dual pass and water meth???????
with 2.6 you will need at bare minimum 60lb fuel injectors and a combo of cooling mods. I highly recommend going with this set up...
2.6
60lb injectors
heat exchanger
injen cold air intake
meth/water injection <---MAJOR THING TO HAVE
1 Step Colder Spark Plugs
And a custom tune
With those you will see a nice gain. Any money left over should go towards header, downpipe and exhaust. After that you will defently want to work on getting better traction.
2.6
60lb injectors
heat exchanger
And a custom tune
Ive got a 2.5 DC exhaust to put on it is that going to be big enough?? also the car came stock with the lsd what else is there to help Im ordering a spec stage 3 clutch tonight and a lightweight flywheel also will konig hotswaps fit the car? I thought about buying wider rims and tires
Some tunes also require diffrent sparkplugs.
I'm tuned with INTENSE-Raceing. People have said its bad tunes, however
I have not had any problem with mine. Works great for me
it's possible, but with a goal like that you're setting yourself up for dissapointment. Without going with nitrous or bigger mods, I wouldn't expect more than 260-270 max on a generous dyno with a great tune.
A/C still doesn't work, and the nitrous mode hasn't been looked at due to lack of testing, but you can definitely utilize the user adjustable rev limit and high octane mode.
I've been bugging Vince to get that done for a while now. I think its just too deeply embedded in the OS to extract in any usable way. At that point it may actually be better to just get the A/C working instead.
I'm currently Trifecta tuned on my TVS 80mm pulley setup, and will be switching to the S3 OS as soon as Vince gets back from the land of coconuts and grass skirts. At that point, I hope to be his guinea pig for unlocking the A/C.
Shameless plea for support:
I know we have a lot of HP Tuned LSJs on this board, myself included when I switch PCMs, but it would be great if more LSJs got Trifecta tuned. I think an increase in support ($$$) could lead to really amazing things for us. (switchable tune, no lift shift, launch control, S3 HOM, S3 user rev limit, etc.). Lots of untapped potential there.
[/threadjack]
[/threadjack]
well right now im in afghanistan but I will be back in april on mid deployment leave Ive heard he can really tune and he laid my buddys 91 gst eclipse out and that thing is fast so I sent him a pm hoping he can tune it while im back on leave
NoBalt123
Sep 4, 2015 07:10 AM
