AEM UEGO Wideband Install Question....
Old Aug 23, 2007 | 09:00 PM
Rangerondubz's Avatar
Question AEM UEGO Wideband Install Question....
Okay so I see that it says this in the PDF Instructions:
But what I dont understand is would this picture be relating to looking down from the top at a 10 degree angle or looking up from the bottom at a 10 degree angle? Any help would be appreciated and would result in +1 Rep, Thanks
Old Aug 23, 2007 | 09:05 PM
Area47's Avatar
Rent me! per hour
side view
or down the pipe itself
Old Aug 23, 2007 | 09:06 PM
Originally Posted by Area47
side view
Okay im just not understanding, can you be more specific?
Old Aug 23, 2007 | 09:07 PM
BlackSS05's Avatar
it means angle it upwards.
Old Aug 23, 2007 | 09:09 PM
Area47's Avatar
Rent me! per hour
when you look down a piece of pipe, you will find that the 10 degree angle on the 02 sensor itself is from looking down the pipe.
Old Aug 23, 2007 | 09:11 PM
Eng@RebelAutoWorxs's Avatar
it's so you don't get condensation of the tip which will eventually mess up the sensor
Old Aug 23, 2007 | 09:29 PM
Damn this is confusing....
Old Aug 23, 2007 | 09:59 PM
BooSSted's Avatar
Ok, all you have to do it make sure the sensor goes into the top half of the pipe so the tip of the sensor inside the DP is pointing towards the ground, it doesn't need to be exactly 10 degrees. It needs to point down so that condensation doesn't build up in the sensor.
Old Aug 23, 2007 | 10:14 PM
Oh okay, so gravity can take effect and let the "condensation" drain? So dont have it directly on the side, have it up just alitlle?
Also, what do I do if metal shavings get into the Cat? Is there anyway I can avoid this?
Last edited by Rangerondubz; Aug 23, 2007 at 10:14 PM. Reason: Automerged Doublepost
Old Aug 23, 2007 | 10:20 PM
BooSSted's Avatar
Your more than likely going to have to take the DP out to get the hole drilled and the bung welded in. When you drill the hole, just turn the pipe on end so the shavings fall out. Taking it out will make life a hell of a lot easier.
Old Aug 23, 2007 | 10:29 PM
Well I would but my DP is welded to my Catback soooo what should I do?
Old Aug 23, 2007 | 10:31 PM
BooSSted's Avatar
Cut it off and re-weld it?? I don't know dude, I don't see how your going to be able to properly weld in a bung with the DP still on the car.
Old Aug 23, 2007 | 10:38 PM
2K5SS/SC?'s Avatar
The downpipe will have to come out for this. You will however need to mark and double check the clearence where you are going to put the sensor due to it's length and wiring. It has to be at an angle about 10* up from the horizontal centerline of the pipe. The reason is so that the condensation doesn't build up in the sensor causing inaccurate readings. Drill a for the bung with the appropriate size. Weld or have the bung welded in. (Local muffler shop can do it in a minute or two if you don't have a welder.) Reinstall the downpipe with new gaskets as an exhaust leak will cause inaccurate readings as well. Hook up all the wires, I suggest a "Add-a-circuit" from the autoparts store for you power wire hooked up into the fuse panel on the passenger side center console panel so it only comes on when the car is turned on, and you'll be up an running. PM me if you need more help bro. I've had to do this in a couple of different cars now.
Go to the parts store. In the exhaust section they sell a metallic gasket with two flanges for 3" pipe. Take the car to an exhaust shop and have them cut the downpipe to install the 3 bolt flanges/gasket and weld in the bung while they're at it. Have them double check the clearence with the sensor since they'll be in there. Thus, you can take it back out at a later date if necessary, and you'll get a great seal still.
Old Aug 23, 2007 | 10:50 PM
Damn I wish I didnt have to take the DP off, so I guess il have to unbolt it from the header then have it cut off from the Catback and then have it welded and bolted back on after im done, thanks for the help 2K5, and yes I will PM you if I have any other questions!
Old Aug 23, 2007 | 10:53 PM
2K5SS/SC?'s Avatar
Yup, unfortunately that is what must be done. It'll be a lot easier in the future though.
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
justinchinn
Oct 2, 2015 12:18 PM
n20saturn
Sep 30, 2015 12:26 AM
yellow dragon
Sep 28, 2015 09:49 PM
