Aeroforce Help
Aeroforce Help
I installed my Interceptor gauge today and did a few runs with it. My IAT1 is at 78 and IAT2 is at 98 when im cruising at 60 or so. Horsepower was at about 220. Im in illinois where the elevation is only like 600 ft. All I have for mods is Injen intake, magnaflow exhaust and CXracing heat exchanger. Does this all make sense? How accurate is this gauge at my current settings? I get my stage 2 installed monday so i just want know some baselines. thanks guys.
Set your alt to 600 and set your HP Adjustment to .85
That is near spot on for me (the HP Adjustment, not the alt).
If the altitude is entered right for your location, with the right HP Adjustment you would have ~248whp. If your higher then sea level, it will be lower.
Last edited by InfinityzeN; May 16, 2008 at 07:25 PM. Reason: Automerged Doublepost
My Shift Lights Are Set At 5500 And They Come On. I Would Lower The Setpoint To Make Sure That It Works And You Have To Set Your Datalog To 1 For The Shift Lights To Turn On
I Would Also Like To Know How My Iats Compare To A Cobalt Without A Cxracing Heat Exchanger. They Seemed To Be Good I Thought Considering My Coolant Temp Never Goes Over 185 Unless Im Stopped At A Light For A Long Time.
Your intercooler coolant and engine coolant are separate systems. Don't think because your engine coolant is 185 that effects your IAT2s. Yes, at idle sitting still your IAT2s will be higher. I have a 2.9" pulley with a cobra h/e and I get about 15-20° over IAT2 cruising.
So I Should Be Reading My Iat2 20 Degrees Hotter Than Iat1 With My Cxr Heat Exchanger ? So A Iat2 Below 100 Is Pretty Good Or What? What Do Stock Cobalts Read?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
